Converting String to Int in C: Issues with atoi() and isdigit() | Code Solution
  • Thread starter Thread starter TheSourceCode
The discussion revolves around the challenges of converting a string of numeric characters into an integer array in C, specifically using the functions atoi() and isdigit(). Participants explore various approaches and clarify concepts related to string handling and ASCII values.
  • One participant presents a code snippet attempting to use atoi() and isdigit() to convert a string of numbers into an integer array but encounters issues.
  • Another participant suggests using a debugger to track variable changes for better understanding and recommends calling atoi() on substrings starting from the index of the next number.
  • A different participant expresses difficulty in using a debugger and mentions a lack of experience with pointers, indicating uncertainty about their use in the solution.
  • One participant clarifies that a string in C is an array of characters and questions whether the numbers in the string are represented as ASCII codes, suggesting a method to print ASCII values instead.
  • Another participant explains that a string containing non-numeric characters cannot be converted to an integer using atoi() and provides an alternative method for conversion by directly assigning character values to integers.
Participants express differing views on the best approach to convert strings to integers, with no consensus on a single method. Some focus on the use of atoi() and isdigit(), while others emphasize understanding ASCII values and direct character manipulation.
There are limitations regarding the participants' understanding of pointers and debugging tools, which may affect their ability to implement suggested solutions. Additionally, the discussion does not resolve the best method for handling non-numeric characters in the string.
TheSourceCode
I need to take the values from a string , such as {23 45 67\0}, and store them into an int array. I need to do this with atoi() and isdigit() but I'm having some issues. Here is what I have.
Code:
for(i=0; i<=n; i++){
   num[i]=atoi(str);
   for(j=0; (isdigit(str[j])!=0); j++){
      for(k=0; k<n; k++)
         str[k]=str[k+1];
         n-=1;
   for(j=0; j<n; j++)
      str[k]=str[k+1];
   n-=1;
Have you tried to follow what your code does with a debugger? Watching how the variables change is the best way of understanding what is happening.
I would not copy str content, instead, I would call atoi on a string starting at the place next number starts. Something like atoi(str+index_of_the_character_next_number_starts). I assume you know how pointers and tables work in C.
I wasn't able to figure out how to track variables in a debugger. However, the due date was extended so I will sit down this weekend and try to figure it out. Also, I'll have another chance to talk to the prof tomorrow. We've not done anything with pointers so I'm not sure if that's an option or not; I'll ask. Thanks for the input.
In C, a string is an array of type char. Are the numbers you show the ASCII codes of the characters in the string? For example, in the string "CAB" the actual values in memory are 67 65 66 0. If all you need to do is print the ASCII values of the characters, just loop through the string to get each character, but use printf to display it as an int.
A string which contains "123" in memory would look like this:
31h
32h
33h
this because the the ASCII correspondents of numbers are 30h for 0 up to 39h for 9.
so if the string has "asdasd" this cannot be converted to int using atoi(). The string should only contain characters with ASCII code varying from 30h to 39h.
If you want to convert characters to int, then simply do this.if we have
str (char array), num (int array), n = strlen(str) then do this
for(int i=0;i<n;i++) {
num = str;
20K
