What Is the Wavelength of the Earth According to De Broglie's Equation?
  • Context: Graduate
  • Thread starter Thread starter 96hicksy
    Earth Wavelength
The discussion revolves around the application of De Broglie's equation to calculate the wavelength of the Earth, exploring the implications of such a small wavelength in terms of wave-particle duality.
  • One participant calculates the Earth's wavelength using De Broglie's equation and finds it to be approximately 3.697×10^-63 meters, expressing surprise at the result.
  • Another participant suggests that the small wavelength indicates the Earth is unlikely to exhibit wave-like properties, emphasizing its particle-like behavior instead.
  • A third participant notes that the de Broglie wavelength is significant primarily for small objects, implying that larger objects like the Earth do not demonstrate measurable wave effects.
  • A participant corrects a misunderstanding regarding Planck's constant, clarifying that it is not the same as Planck's length.
Participants generally agree on the implications of the small wavelength, but there is a lack of consensus on the significance and interpretation of the results, as well as some confusion regarding terminology.
Participants express uncertainty about the implications of the calculated wavelength and its relation to wave-particle duality, as well as the distinction between Planck's constant and Planck's length.
This discussion may be of interest to students and enthusiasts of physics, particularly those exploring concepts of wave-particle duality and the implications of De Broglie's theory.
96hicksy
So I was reading about De Broglie's theory of particle-wave duality the other day and I came across the equation: λ=h/p. I expect most of you are familiar with this equation but if you're not, it is: wavelength = Planck's length over momentum (mass x velocity).
So I thought i'd try and find the Earth's wavelength.
So first I found out what I would have to do to find p, which is (5.9742x1024kg * (approx) 3x104 m/s).
So... 6.626x10-34/(5.9742x1024kg * (approx) 3x104 m/s)
This is equal to... 3.697×10^-63 meters.
When I first saw that, I was mind blown. Will someone explain why it's wavelength is that small?
Thanks, Ben - I'm unsure of this because well, I'm quite young (15).
The question should not be why the wavelength is small (the numbers simply make it so), the question should be what it means.
And such small a wavelength means that the Earth (if we consider it as a monolithic ball) is highly unlikely to exhibit any wave-like properties (to interfere, diffract, etc.) and is much more particle-like than wave-like.
By the way, it is nice to hear of someone who managed to find out about and become interested in De Broiglie's waves at the age of 15. Cheers!
Oh, and h is not Planck's length, it is Planck's constant. You got the number correct, though. Planck's length is a related but different thing.
No need to worry too much about this. The de Broglie wavelength only starts to show itself for small objects (particles), which really do tend to get bent round corners when they go through a narrow slot. You can spend a lot of time watching people walk through a doorway, waiting for them to be diffracted. It ain't going to happen to any measurable degree :wink:
Thanks guys! Slight confusion on Plancks constant, so sorry for that!
