Whats wrong with this torque set up
  • Thread starter Thread starter Jacob87411
    Set Torque
The discussion centers on calculating the forces acting on a man performing push-ups, weighing 70 KG, with a center of gravity positioned 25 cm from his hands and 73 cm from his feet. The torque equation used is Στ = (-70)(9.8)(0.25) + (0.98)(Force of Feet), leading to a calculated force of 175 N on the feet. However, the correct distribution shows that the hands bear 511 N, indicating a significant discrepancy due to rounding in the reference material. The 30 cm height of the center of gravity was deemed irrelevant to the calculations.
  • Understanding of basic physics concepts, particularly torque and force.
  • Familiarity with the principles of static equilibrium.
  • Knowledge of weight distribution in biomechanics.
  • Ability to perform calculations involving gravitational force (9.8 m/s²).
  • Study the principles of torque in static systems.
  • Learn about weight distribution during physical activities like push-ups.
  • Explore advanced biomechanics related to human movement.
  • Investigate the effects of body positioning on force distribution.
Fitness enthusiasts, biomechanics students, physical trainers, and anyone interested in understanding the physics of body weight exercises.
Jacob87411
The problem involves a man doing push ups, he weighs 70 KG. It wants to know the force on each hand and each foot. His center of gravity is 25 cm from his two hands, and 73 cm from his feet. The center of gravity is also 30 cm above both is hands and feet.
Using the hands as the rotation point, weight bearing down negative, force of the ground on the feet upwards
Sum of the torque equals 0 = (-70)(9.8)(.25) + (.98)(Force of Feet)
This comes out to be 175 N, which I know is incorrect, but do not see what is wrong with the set up. Obviously the hands should be bearing a decent amount more than the feet.
175 N on the feet and 511 N for the Hands 511N>175N your work is right
Ah, stupid book must have rounded a lot, that's why I thought I was off, thanks, so the 30 cm was useless info
