New Reply
Electronics - Flip-Flop D
Share Thread
Mar5-12, 07:42 PM   #1
Recognitions:
Gold Membership Gold Member
In the following drawing is given a intro signal to flip-flop type D, negative edge triggered. Also is given the clock pulse signal. Copy to your notebooks these signals and add intro signal Q. Presume that in starting condition Q=0. Also, neglect the delay times of the flop-flop
Mine is the pencil of course. Does it make sense?
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Mar5-12, 09:19 PM   #2
Recognitions:
Homework Helper Homework Help
Hi!
Q remains 0 until the Cp pulse goes down.
At that time Q becomes and stays 1 (since the D signal is 1 at that time).
The D flip-flop stores the D signal at the negative edge of the clock pulse.
This means that when the clock pulse (Cp) goes down, the Q state changes.
Q becomes the state of the D signal at that time.
Mar6-12, 12:01 AM   #3
Recognitions:
Alright, as per your criticism...
What exactly is the negative edge of the clock pulse? Oh, you mean like when an AC current reaches negative current?
Mar6-12, 07:10 AM   #4
Recognitions:
Quote by Femme_physics View Post
The negative edge is where the clock pulse goes down (negative slope), which is the right side of the pulse.
AC current does not have a sharp edge like that.
The only place where Q can change is at that edge.
Mar6-12, 09:28 AM   #5
Recognitions:
From my hobby days I seem to recall that D flip-flops are rising edge triggered. Do they make them both ways now?
Mar6-12, 09:34 AM   #6
Recognitions:
Quote by LCKurtz View Post
According to wiki:
"The D flip-flop captures the value of the D-input at a definite portion of the clock cycle (such as the rising edge of the clock)."
Wiki seems to imply they are made both ways.
And the problem statement says it's the falling edge.
Mar9-12, 04:47 AM   #7
Recognitions:
Quote by I like Serena View Post
But the graphs only have positive edge?
Mar9-12, 04:58 AM   #8
Recognitions:
What do you mean by positive edge?
The graphs have both positive edges and negative edges.
Each pulse starts with a positive edge, also called the rising edge.
And each pulse ends with a negative edge, also called the falling edge.
Mar9-12, 05:02 AM   #9
Recognitions:
But I have both D and CP for reference. Now I know CP is the clock pulse. D is the input.
If Q can only change at NEGATIVE clock pulse edge, then I stand by my last diagram
Mar9-12, 05:38 AM   #10
Recognitions:
In your last diagram Q changes at the rising edge of the clock pulse...
EDIT: A negative edge does NOT mean that the signal is negative, but is means that the level of the signal goes down.
Mar9-12, 07:19 AM   #11
Recognitions:
The graphs are drawn to appear to have only positive levels, yes. But these waveforms are logic levels, not voltages, so they are never going to have negative levels. Logic is 1 or 0.
The transition from logic 0 to logic 1, denoted 0→1, is termed the "rising edge" or positive edge. When the logic level changes back to 0, the transition 1→0 is termed the "falling edge" or negative edge. (It has nothing to do with + or - voltages.)
Your Q output is so wrong that I suggest you erase it so you don't keep referring back to it, and can start again with a fresh outlook.
:::NEXT LINE EDITED::::
First step, trace the vertical dotted line from each clock pulse's 1→0 tranistion and mark these faintly on the Q graph--these mark the only place where the Q level can change logic levels because you are told that your D flip-flop is negative-edge triggered.
Mar14-12, 11:06 AM   #12
Recognitions:
Is this correct then?
Mar14-12, 11:07 AM   #13
Recognitions:
Yep!
Mar14-12, 11:07 AM   #14
Recognitions:
Jun12-12, 02:09 AM   #15
Recognitions:
*bumps*
Would my graph be any different if this was a positive edge triggered D-FF flip-flop, and not negative D-FF flip-flop?
Jun12-12, 02:11 AM   #16
Recognitions:
*bump back*
Yes.
What do you think it would look like?
Jun12-12, 02:23 AM   #17
Recognitions:
I'm actually really confused about my answer from before.
According to the truth table of D flip-flops
When D = 1 and CLK = 1
then Q = 1
Since ours is negative on the first dotted line we still kept it zero. Ok.
On the second dotted line we have D = 1 and CLK = 0
That's "no change" on both Q and Q(capped)...yet we changed Q to "1" digital. Something doesn't add up here.
New Reply
Similar discussions for: Electronics - Flip-Flop D
Thread Forum Replies
Need help with D Flip Flop Engineering, Comp Sci, & Technology Homework 2
T Flip-Flop Using A D Flip-Flop HDL? Engineering, Comp Sci, & Technology Homework 1
Drawing D flip flop using T flip flop Engineering, Comp Sci, & Technology Homework 2
j-k flip flop Engineering, Comp Sci, & Technology Homework 3
jk flip flop Engineering, Comp Sci, & Technology Homework 3
