Question about the natural numbers?
The discussion revolves around the concept of infinitely decreasing sequences within the context of natural numbers and rational numbers. Participants explore the implications of starting from a theoretical point like ω and the feasibility of mapping rational sequences to natural numbers.
  • Some participants question the possibility of having an infinitely decreasing set of natural numbers, noting that starting from ω is ill-defined and that natural numbers are finite.
  • One participant suggests that if infinitely increasing sequences exist in natural numbers, then an infinitely decreasing sequence should also be possible, but acknowledges the challenges in defining such a sequence.
  • Another participant emphasizes that ω is not a natural number and questions what the first element of a proposed decreasing sequence would be.
  • Some participants propose that infinitely decreasing sets exist in positive rationals, suggesting a mapping from rationals to natural numbers using prime bases, but express uncertainty about the validity of this mapping.
  • Concerns are raised about whether the mapping from rationals to natural numbers would preserve the decreasing nature of the sequence.
  • Participants discuss the idea of ordering sets of rational numbers and the challenges associated with this approach.
  • One participant reflects on the difficulty of constructing a valid infinitely decreasing sequence, acknowledging the complexity of the problem.
Participants generally disagree on the feasibility of infinitely decreasing sequences in natural numbers, with some asserting it is impossible while others explore potential mappings from rational numbers. The discussion remains unresolved regarding the validity of these mappings and the existence of such sequences.
Limitations include the unclear definitions of sequences starting from ω, the challenges in mapping rational numbers to natural numbers, and the implications of ordering sets of rational numbers.
cragar
My teacher was saying that we can't have a set of infinitely decreasing natural numbers.
What if we started at ω and then worked our way backwards. I realize that is ill defined.
And where ever we start will be a finite number. But if we can have an infinitely increasing set in the natural numbers, why can't we just run this backwards.
First of all, [itex]\omega[/itex] is not a natural number. It is defined as something larger than all natural numbers, but it's not a natural number.
Let's say you have an increasing sequence 1,2,3,4,5,6,...
You suggest to run it backwards. Well, what would be the first element of the sequence??
Remember that [itex]\omega[/itex] is not a natural numbers. And [itex]\omega-1[/itex] isn't even well-defined.
ok i get what your saying, I was just wondering if there was some clever way to get around it.
No, there isn't. An easy intuitive way to see this is as follows:
Let's have an infinite decreasing sequence of natural numbers. Let the first element be n. But then you can only have n elements after it.
For example, let the first element be 3224. Then the subsequent elements can only be 1,2,...,3223. So you can only have a finite number of elements after. So you can never infinitely decrease.
ok, I might be beating a dead horse. But i just want to say, we can have infinitely decreasing sets in the positive rationals, so why can't we just map these rationals to natural numbers using prime bases like [itex]5^p7^q[/itex] . There is probably something I am missing about the rationals.
Sure: 1/n is a good infinitely decreasing sequence. So we can find it in the rationals.
But how would you transfer this sequence to the set of rational numbers? What is the map you use?
And more importantly: will the image under this map still be decreasing? I claim that it will not end up being a decreasing sequence.
Your mapping will not generate an infinitely decreasing sequence in the natural numbers; it won't even be decreasing. Given rational numbers 1/p < 1/q, the former is mapped to a greater natural number than the latter.
ok so well start with small rationals and then go up to bigger rationals . Why can't we just order the set later.
What do you mean??
The best way to see why it fails is to try the idea out. So try it out on a example and post your results.
ok i see why it fails now, it seems like you might have been able to carefully pick rationals in such a way as to make it happen, but apparently not. Interesting to think about though.
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 55 ·
11K
  • · Replies 16 ·
