| New Reply |
Spontaneous drug release rate equation |
Share Thread | Thread Tools |
| Mar8-12, 06:13 AM | #1 |
Okay I found some references and the equation I am after is
Q = 2 * C * (D * t / ∏)^(1/2) where Q is the weight of drug released per unit area (hence unit is mg/cm^2) C is the initial drug concentration D is the diffusion coefficient (unit of cm^2 min^-1) and t is release time in min. What I am not sure about is the units. Logically the concentration of drug would be in g/L. but when I merge all the units together, I get something else. This is my working. The units on the right hand side should equals to Q. = 2 (constant) * C (g/L) * [D (cm^2 * min^-1) * t (min) / ∏ (constant)]^(1/2) only considering units (ie discard constants) = [g * cm^[2*(1/2)] * min^(1/2)] / [L * min^(-1 * 1/2)] = g * cm * min^(1/2) / L * min^(-1/2) = g * cm * min^(1/4) / L which does not equals to unit of Q (mg/cm^2). The units given are all correct but is there something I am missing here? Breaking rules of powers perhaps? Thank you!!!! |
| Mar8-12, 08:44 AM | #2 |
Admin
You are doing strange things, difficult to follow.
What is $$ \sqrt {\frac {cm^2} {min} \times {min} }$$ equal to? |
| Mar8-12, 03:34 PM | #3 |
I think that should equals to just "cm" If you look at the attachment, equation 24, that is what I am after and the units were taken from other sources. But to me, equation makes sense but units don't from what I did. Is there a problem with my algebra skill? |
| Mar8-12, 04:08 PM | #4 |
Admin
| Mar8-12, 08:20 PM | #5 |
then it would equals to mg / cm^2.... which is the unit of Q.
where did you get mg/cm^3? oh wait... damn it.... you changed L into cm^3... thank you so much |
| New Reply |
| Thread Tools | |
Similar Threads for: Spontaneous drug release rate equation
| Calculating rate law equation by determining initial rate of oxygen produced | Biology, Chemistry & Other Homework | 8 | ||
| Spontaneous fission rate to half-life equivalence | Introductory Physics Homework | 2 | ||
| rate of reaction, rate constants, and Arrhenius' Equation | Introductory Physics Homework | 0 | ||
| Finding the rate equation and rate constant | Biology, Chemistry & Other Homework | 0 | ||
