How can we define the induced metric on a brane?
  • Context: Graduate
  • Thread starter Thread starter atrahasis
    Induced Metric
The discussion revolves around the concept of the induced metric on a brane within the context of brane models in theoretical physics. Participants explore the mathematical formulation of the induced metric, its relationship to the bulk metric, and the implications of different coordinate systems.
  • One participant expresses confusion regarding the definition of the induced metric, noting the relationship between the bulk metric and the induced metric as given by the projection tensor.
  • Another participant corrects their earlier statement about the normal vector, suggesting a revised form to ensure the normalization condition is satisfied.
  • A different perspective is introduced, discussing two ways to conceptualize the induced metric: as a 4D metric tangent to the surface and as a genuine 3D object, emphasizing the need for adapted coordinates to see the 3D metric clearly.
  • One participant acknowledges their misunderstanding, clarifying that the projection tensor does not represent the induced metric and that the induced metric should be derived from the tangential components of the tensor.
  • Further elaboration is provided on how to compute the induced metric by considering the basis vectors orthogonal to the normal vector and how to derive the correct components from the bulk metric.
Participants do not reach a consensus on the definition and calculation of the induced metric, with multiple viewpoints and approaches presented throughout the discussion.
Participants highlight the importance of coordinate systems in understanding the induced metric, suggesting that the relationship between the 4D and 3D perspectives may depend on specific choices of coordinates.
atrahasis
Hello,
I have a problem to understand what people say by "induced metric". In many papers, it is written that for brane models, if we consider the metric on the bulk as [itex]g_{\mu\nu}[/itex] hence the one in the brane is [itex]h_{\mu\nu}=g_{\mu\nu}-n_\mu n_{\nu}[/itex] where [itex]n_{\mu}[/itex] is the normalized spacelike normal vector to the brane. I agree that it defines a projection tensor since [itex]h_{\mu\nu}n^{\mu}=0[/itex] but I don't understand how this can be the induced metric on the brane.
For example, if we consider a flat spacetime in spherical coordinates:
[itex]ds^2=-dt^2+dr^2+r^2\Bigl(d\theta^2+sin^2\theta d\phi^2\Bigr)[/itex]
and we consider the surface defined by the equation [itex]r=a(t)[/itex], hence we have
[itex]ds^2=-\Bigl(1-\dot a^2\Bigr)dt^2+a^2\Bigl(d\theta^2+sin^2\theta d\phi^2\Bigr)[/itex]
which is for me the induced metric on the surface. But it doesn't match with the metric [itex]h_{\mu\nu}[/itex] where [itex]n_\mu=(0,1,0,0)[/itex]
which would give [itex]h_{00}=-1\neq -\Bigl(1-\dot a^2\Bigr)[/itex] ?
Ok I have half of the answer, the normal vector is wrong, because [itex]r=a(t)[/itex], we have [itex]dr-\dot a dt=0[/itex], which gives for the normal vector [itex]n^\mu=n(-\dot a,1,0,0)[/itex] with [itex]n[/itex] a normalization factor in the goal to have [itex]g_{\mu\nu}n^\mu n^\nu=+1[/itex].
But I still don't have the right induced metric
There are two ways of thinking about the induced metric. One is the way you've given, as a 4D metric that is "tangent" to the surface. The other is as a genuine 3D object. What I think you are asking is why, when you use the 4D definition, you don't suddenly see a 3D metric pop out in front of you. You will see this only in "adapted" coordinates in the sense that the hypersurface is described by holding one of the coordinates fixed. If you want to translate between the 4D induced metric and a genuine 3D metric when you're not working in adapted coordinates, you have to effectively work out the coordinate transformation. For the 3D viewpoint you should read the excellent treatment given in Eric Poisson's book, "A Relativist's Toolkit".
This was a bit vague I think it will still help you answer your questions. Also note that I worked with the example of a 3D surface in a 4D spacetime, but the same logic works generally. (Note that there are new subtleties with null surfaces, however.)
Thanks for the reply,
I checked on Poisson's book and also Gourgoulhon's review but I couldn't found the reason.
I finally understood my mistake, [itex]h_{\mu\nu}[/itex] is not the induced metric but only the projection tensor. For to have the induced metric we have to look to the tangential components of the tensor and not to [itex]h_{00}[/itex].
In fact the 3 vectors orthogonal to the normal vector and which define a basis on the hypersurface are
[itex]V1^\mu=(1,\dot a,0,0)[/itex]
[itex]V2^\mu=(0,0,1,0)[/itex]
[itex]V3^\mu=(0,0,0,1)[/itex]
so it is perfectly fine to look for [itex]h_{22}[/itex] and [itex]h_{33}[/itex]. But the last component is not [itex]h_{00}=h_{tt}[/itex] but [itex]h_{V1 V1}[/itex]
So now we have [itex]\partial_{V1}=\partial_t+\dot a \partial_\rho[/itex] which implies that
[itex]h_{V1V1}=h_{00}+2\dot a h_{01}+\dot a^2 h_{11}[/itex] which gives the correct result [itex]h_{V1V1}=-1+\dot a^2[/itex].
So it is a modification of the coordinates ...
Thanks
  • · Replies 16 ·
  • · Replies 76 ·
  • · Replies 30 ·
  • · Replies 28 ·
