| New Reply |
Work Energy and Kinematics |
Share Thread | Thread Tools |
| Mar9-12, 10:40 AM | #1 |
Please forgive me if the answer to this question is obvious, I studied Political Science for three years in undergrad before I realized 'real' science was far more rewarding.
My question (not homework): I understand that Work-Energy can be used for projectile motion, if what you're after is not time dependent. I also find that working with W.E. is more intuitive for me than the kinematics equations. Say I have a projectile that is launched at some angle < 90°, at some velocity and I want to know what the maximum height the projectile reaches in its flight. We will assume no air resistance and that height initial = height final. So figuring out the maximum height of the projectile with kinematics is easy enough, but with W.E. it's not so straight forward. I know that maximum height along the path would occur where PE has the highest value along the entire path. KE would never be zero because the projectile never stops moving, only slows a little at maximum height. So how (if possible) can I use W.E. to look at a problem like this? Thank you. |
| Mar9-12, 03:34 PM | #2 |
hi whiskeySierra! welcome to pf!
![]() because you know that the horizontal component of velocity is constant, and that will be the minimum KE (instead of 0)
| Mar12-12, 06:38 AM | #3 |
Could we not say this occurs when the vertical component of velocity is zero?
| Mar12-12, 06:55 AM | #4 |
Recognitions:
| New Reply |
| Thread Tools | |
Similar Threads for: Work Energy and Kinematics
| work/energy/kinematics rocket ship problem | Introductory Physics Homework | 1 | ||
| work energy theorem vs Newton's 2nd law and kinematics | Classical Physics | 4 | ||
| kinematics, work-energy, conservation, more, less? | Introductory Physics Homework | 4 | ||
| Help With Kinematics/Work, Energy, Power Problem | Introductory Physics Homework | 1 | ||
| Work-Energy vs. Kinematics | Introductory Physics Homework | 4 | ||
