Do Particles Possess Identical Characteristics?
  • Context: Graduate
  • Thread starter Thread starter MathematicalPhysicist
    Particles
The discussion revolves around the characteristics of particles, particularly whether they possess identical properties. Participants explore theoretical perspectives, mathematical models, and implications of particle identity in the context of quantum mechanics and Bohmian mechanics.
  • Exploratory, Technical explanation, Debate/contested
  • One participant references a paper advocating Bohmian mechanics, suggesting it may influence the discussion on particle characteristics.
  • Another participant questions how the author of the referenced paper addresses the treatment of particles with different spins, specifically comparing electrons and muons, and expresses curiosity about the equations for other particle types.
  • A different viewpoint suggests that if all particles are of one type, it should be feasible to create a computer simulation to demonstrate this, using gravity as a common factor.
  • One participant expresses a belief that all particles are identical, proposing that a model can be constructed where all particles exhibit the same linear force.
Participants present multiple competing views regarding the identity of particles, with no consensus reached on the matter.
Some claims depend on specific definitions of particle types and properties, and the discussion includes unresolved questions about the mathematical treatment of different particles.
http://math.rutgers.edu/~oldstein/papers/aapi.pdf
i haven't yet read it , but the writer is an advocate of bohmian mechanics so i guess there is an influence in this paper from bohm mech.
( ill read it tomorrow).
anyway i think with this kind of a title to paper it should catch some attention, don't you think?
Quite interesting and mathematized this picture,but i couldn't see how he dealt with the problem itself:deing able to treat on equal footing spin different particles.He gave an example with an electron and a muon,which are both soin 1/2 particles.I wonder how his equations would look for an electron and a meson.
Daniel.
If the tiniest particle is of one type, then it should be possible to create a computer simulation where this can be show. eg. consider a particle G. as everything has gravity.
Came across the following when researching this subject:
Are All Particles Identical? by
Sheldon Goldstein, James Taylory, Roderich Tumulkaz, and Nino Zanghox PACS numbers 03.65.Ta. (foundations of quantum mechanics) published September 28, 2004
I subscribe to the view thar all particles are identical because it is a simple matter to construct a model where all particles carry the same linear force.
  • · Replies 62 ·
13K
  • · Replies 35 ·
  • · Replies 33 ·
11K
