Stray or parasitic capacitance
  • Thread starter Thread starter sakhawat
    Capacitance
The discussion focuses on the concept of parasitic capacitance in PNP and NPN transistors, as well as diodes, emphasizing its significance when the junction is reverse biased. It explains that during reverse bias, a depletion layer forms at the junction, which increases in thickness with reverse voltage, effectively creating a capacitor between the conductive P and N materials. The participants highlight that while forward bias conditions render capacitance less impactful, understanding the behavior of the depletion layer is crucial for designing capacitors in PN junctions.
  • Understanding of PNP and NPN transistor operation
  • Knowledge of diode characteristics and behavior
  • Familiarity with reverse biasing and depletion layers
  • Basic principles of capacitance and capacitors
  • Research the effects of reverse bias on PN junction diodes
  • Study the design and application of capacitors in semiconductor devices
  • Explore the concept of stray capacitance in electronic circuits
  • Learn about the impact of depletion layer thickness on device performance
Electrical engineers, semiconductor device designers, and students studying electronics who seek to deepen their understanding of parasitic capacitance in transistors and diodes.
sakhawat
i have tried a lot but menacingly failed to understand how the parasitic capacitance exists in a pnp or npn transistor or at any diode??
Well, there is a boundary between the P and N junction. Capacitance mostly become important when the junction is reverse biased and is not conducting. When reversed biased, a depletion layer is form at the junction and the thickness increase with the reverse voltage.
Guess how does the reverse biased junction with depletion layer in between? Remember the P and N material is conductive. Sooooo...You have two conductor plate one on each side. In the middle there is a layer that is not conductive ( depletion layer). What does this look like? Two conductive plate with an insulator in between?....A capacitor!
People usually don't care much on the forward biased PN junction as it is conducting. Putting a cap across a conductive wire give you just a conductive wire! At least that is true in the first approximation.
Thanks for this part cause its really have given me a clear assumption of what should be the design of a capacitor in the pn junction diode haha ... and i also got the picture of the stray capacitance that exists in a minimal form in the forward bias . Many many thanks ...
  • · Replies 17 ·
  • · Replies 27 ·
