| New Reply |
Wave -Particle dualtiy, the most convincing evidence? |
Share Thread | Thread Tools |
| Mar12-12, 07:14 AM | #1 |
hello,
i am writing a report on wave particle duality and i have included the experiments you would expect. young's inteference patterns as evidence for light as a wave, and the photo electric effect providing evidence for light as a particle. etc. what i am concerned about is does the photoelectric effect explicitly show light as a particle? i understand that all the energy required for a photon to be ejected must arrive all at once in a 'discrete' (i use this term because i believe it is the correct way to describe this, but i could use some clarification as to what it actually means) packet. this does seem to show that light is a particle. also increasing the intensity of the light does not increse the kinetic energy of the emmitted electrons, but increasing the frequency of the light does(which is a wave idea of light). i know that the conclusion of my report will be that light is a quantum particle that exhibits both wave and particle like behaviour, but is the photo electric effect evidence for light as a particle, or for light as a particle and a wave? that was rather long winded, so i have just one more question. if the photoelectric effect is used to argue that light exhibits both properties, what is a convincing piece of evidence for light just as a particle? i'm sure there must be some, because many great scientists were convinced it was for a long time! thanks for any help you can give. lntz. |
| Mar12-12, 08:05 AM | #2 |
One other piece of 'evidence' that is quoted to show that photons are particles is the fact that they exhibit Momentum (light pressure etc.). But there is a perfectly good Classical explanation of what happens when an EM wave hits a surface (reflecting or absorbing). This also predicts exactly the same forces so you can take your pick as to which explanation you choose (if you have to choose). It may not be too fruitful to fret over What's really what because they're all models which sometimes apply and sometimes aren't so good. I always say that it's over optimistic to think in terms of 'understanding' anything fully. It would be a good idea to use lots of 'qualifying' words in your report, rather than being too dogmatic. (In years to come, it come back and bite you if you're not careful) "OMG how could I have written that!!!?" |
| Mar12-12, 08:10 AM | #3 |
your understanding of the photoelectric effect is excellent - in particular the fact that intensity of light does not affect the energy of the emitted electrons but also recall there is a minimum wavelength to eject electrons at all.
My personal view is the best evidence of the 'particle' nature of light is the Compton effect where a photon 'hits' an electron and scatters off at an angle (with lower energy ie longer wavelength) and the electron recoils gaining the energy lost by the photon. The point is that if you treat the photon as well as the electron as a particle and consider the collision just like two billiard balls you get a equation which exactly describes (ie energy and angles) what is experientially observed. Another experiment (which I well recall doing as an undergraduate) is to shine a very weak beam of light through a double slit (Youngs experiment) and detect the light with a photomultiplier (uses the photoelectric effect to produce a 'click' when a photon hits it). If you make the light intensity so low that only one photon can be in the apparatus at any one time a very strange thing happens - add up all the 'clicks' (ie particles of light) you still get an interference pattern which is a wave property. A good basic level explication of this is given in Feynmans book 'QED the strange theory of light and matter' Hope this helps Regards Sam PS you mention 'discrete' it just means not spread out in space and / or time |
| Mar12-12, 08:14 AM | #4 |
| Mar12-12, 08:25 AM | #5 |
Sam |
| Mar12-12, 08:26 AM | #6 |
I recall Heisenberg but how does that apply to the term 'discrete'? It refers to uncertainty.
| Mar12-12, 09:05 AM | #7 |
Sorry INTZ this has only at best tangential importance to your question
Discrete is only a model. There are no such things as discrete energy levels or positions or momenta but they are useful (Think of Fermi's model of β decay as a point interaction ie discrete interaction before the W and Z where discovered) Hence my reference to Heisenberg Discrete is also used in classical mechanics - I mentioned billiard balls in my original response it is modelled as a discrete interaction ie at a precise point in space and taking zero time but I hear a sound when two billiard balls collide so 'discrete' is not possible but a useful model Regards Sam |
| Mar12-12, 09:07 AM | #8 |
Recognitions:
| Mar12-12, 09:43 AM | #9 |
The abstract of the paper you quote mentions evidence of quantisation and not of particles. I am not a subscriber so I couldn't read the full article. |
| Mar12-12, 10:02 AM | #10 |
Recognitions:
To be honest I do not understand your answer.
I am still pretty puzzled where your problem is. This is THE standard experiment performed to identify and demonstrate single-photon sources which is routinely performed in labs all over the world and has been performed and published more than 1000 times. |
| Mar12-12, 10:09 AM | #11 |
| Mar12-12, 10:22 AM | #12 |
Recognitions:
| Mar12-12, 10:31 AM | #13 |
Mentor
In hindsight, one can argue plausibly that it was not a good idea to carry over the word "particle" from the classical world to the quantum one, because it carries along too much ontological baggage that leads to misconceptions about how photons, electrons, etc. behave and what they "really are."
But that ship sailed many decades ago, and it's probably impossible to call it back to port now. |
| Mar12-12, 10:32 AM | #14 |
Exactly. Doesn't that highly important idea warrant being given its own name? It has confused generations of people into a far too mechanical view of the things. You are in a small minority of people who don't actually think in terms of 'little bullets'.
| Mar12-12, 10:40 AM | #15 |
Recognitions:
I fully agree that the terminology can be confusing for laymen. However, technology terms often use words known from everyday usage and places them in a different context. I suppose the problem is that the terminology has grown historically and it might be pretty complicated to change it. I suppose you would need an authority in the field and many agreeing followers to change the terminology used. While it would indeed be a good thing from a pedagogical point of view to change the wording, I am afraid the probability of that really happening is rather small.
| Mar12-12, 10:41 AM | #16 |
A lot of stuff on PF just happens to be at that level where these terms cause most aggro.
| Mar12-12, 01:30 PM | #17 |
Hey, long time reader, first time poster here.
Thanks! |
| New Reply |
| Thread Tools | |
Similar Threads for: Wave -Particle dualtiy, the most convincing evidence?
| Evidence that electron is a point particle? | Quantum Physics | 4 | ||
| Evidence that light is electromagnetic wave | General Physics | 1 | ||
| Evidence that light is a transverse wave? | General Physics | 2 | ||
| What is the evidence for a higgs particle? | High Energy, Nuclear, Particle Physics | 9 | ||
| wave particle dualtiy and neutron diffraction | Advanced Physics Homework | 1 | ||
