Use of superposition in Simple Circuits and Norton equivalent
The discussion focuses on applying superposition to analyze a circuit with a light bulb modeled by resistor R3 and finding its Norton equivalent as seen by the independent current source iS2. The user initially misapplied superposition by removing dependent sources, leading to incorrect calculations. After revisions, the correct current iX was determined to be 133/75000 A, and the power delivered by the independent current source was confirmed to be exactly 8 mW. The key takeaway is to retain dependent sources during superposition analysis.
  • Understanding of superposition theorem in circuit analysis
  • Familiarity with dependent and independent sources in electrical circuits
  • Knowledge of Norton and Thevenin equivalents
  • Proficiency in mesh analysis and node-voltage methods
  • Study the superposition theorem in detail, focusing on its application in circuits with dependent sources
  • Learn how to derive Norton and Thevenin equivalents from complex circuits
  • Practice mesh analysis techniques for solving circuit problems
  • Explore advanced circuit simulation tools like LTspice for validating circuit analysis results
Electrical engineering students, circuit designers, and anyone involved in circuit analysis and design will benefit from this discussion, particularly those looking to deepen their understanding of superposition and equivalent circuits.
rock42
The problem statement
7. In the circuit below, the resistor R3 models a light bulb.
a) Use superposition to find iX.
b) Find the Norton equivalent as seen by the independent current source, iS2.
c) Find the power delivered by the independent current source, iS2, in the circuit below.
Diagram attached!
The attempt at a solution
I have yet to learn superposition in class, so forgive me if I am more than a little off the mark, but for part A I removed all sources but one, replacing the Vs with wires and the Cs with breaks.
12V left in: ix = 12/15000 [Amps]
5V left in: ix = 5/15000 [Amps]
.01A left in: ix = -.01 [Amps]
Dependent sources, when in a circuit by themselves, result in a zero current. Correct?
By Superposition ix= 17/15000 [amps] (Part A)
Removing the 10[mA] Cs, I now am searching for V(open circuit) and i(short Circuit).
I suppose this is wear my questions kick in (assuming I was correct before regarding superposition). Can I say that this new ix (it has changed since I removed the 10[mA] Cs) is the old ix plus .01[A]? Reworking superposition tells me I can, but I may be wrong entirely regarding superposition.
Regardless, Solving for Voc and Isc gives my Norton/Thev circuit that is incorrect. (I have selected answers and I am told that the power delivered by the 10[mA] Cs is ~8[mW])
Edit the First:
I have revised my answer for part A to 133/75000 [A] after discovering that dependent sources are to be left in when computing superposition.
Edit the Second:
I have checked my answer for A and found it to be correct via node-voltage method. For some reason I am still getting incorrect Thev/Norton circuits.
Edit the Third:
I have solved the problem, I was making an odd error solving for the short circuit current that was ultimately resolved by redoing the problem and using current mesh method when solving for Isc. The result came to be exactly 8[mW] not an approximation.
You'll need to leave any dependent sources in place. Independent sources can be suppressed leaving one active at a time.
  • · Replies 28 ·
  • · Replies 35 ·
