Why is the temperature of a non-equilibrium system undefined?
The discussion revolves around the concept of temperature in non-equilibrium systems, particularly in the context of thermodynamics. Participants explore the definitions and implications of temperature, its measurement, and the conditions under which it can be considered defined or undefined.
  • One participant expresses confusion over the statement that "the temperature of a non-equilibrium system is undefined," questioning the consistency with the definition of temperature as a measure of average kinetic energy.
  • Another participant suggests that a non-equilibrium system, such as a hot metal in cold water, may have a defined equilibrium temperature, but that temperature does not exist uniformly within the system.
  • A different viewpoint asserts that thermodynamic parameters, including temperature, are only defined in equilibrium states, and while temperature can be discussed in quasi-static processes, it cannot be used in equations for non-equilibrium systems.
  • Some participants argue that temperature can still be defined for non-equilibrium systems, citing examples like a cooking turkey, which has a measurable temperature despite being out of thermal equilibrium.
  • There is a discussion about the fundamental definition of temperature as the partial derivative of internal energy with respect to entropy, and whether this definition applies meaningfully in equilibrium conditions.
  • One participant emphasizes that temperature is a statistical measure and is only meaningful when applied to large numbers of particles, noting that individual particles do not have a well-defined temperature.
  • Another participant mentions that a measurable temperature gradient is necessary to define temperature in a medium, suggesting that a certain number of particles is required to achieve a useful temperature measurement.
Participants do not reach a consensus on whether temperature can be defined in non-equilibrium systems. Multiple competing views are presented, with some asserting that temperature is undefined in such contexts while others argue it can still be measured.
There are limitations in the discussion regarding the assumptions made about equilibrium and non-equilibrium states, as well as the definitions of temperature and its applicability in various contexts.
Kelvin
Hi, I am taking a thermodynamics course but I am confused when my teacher told me that "the temperature of a non-equilibrium system is undefined".
but as I know, in microscopic world, temperature measures the average kinetic energy of a system, and this seems to be inconsistent with the previous statement.
Can anybody point out the mistakes I have made? Thank you!
Science news on Phys.org
Would your teacher consider a "non-equilibrium system" to be a red hot chunk of metal tossed into a bucket of cold water? The system then consists of the hot metal and the cold water. We might define the temperature of that system as the equilibrium temperature, but that temperature doesn't exist in the system anywhere.
2 different things
All thermodynamic parameters are defined only in Equilibrium State. You can talk of temperature in quazisatatical processes, but not much more than that.
The sentence "Temperature measures the average kinetic energy of a system", is helpull when you try to understand what you're dealing with, but you can't use it in equations. Temperature is really defined as the Internal Energy's partial derivative by the Entropy.
Is "the partial derivative of internal energy by entropy" is a more fundamental definition of temperature? Is the expression
KE = 3/2 kT​
meaningful when the system is in equilibrium? thermodynaimcs parameters are pressure, volume & temperature only?
Q_Goest:
Is that means my teacher was wrong or probably I made some mistakes when jotting notes?
KE = 3/2 kT​
KE=3/2kT is an average KE for one molecule in a system at temperature T. That doesn't mean the molecule has that temperature. Temperature is a statistical measure and only applies to large numbers of molecules. In any gas, a given molecule can be moving at a wide range of speeds because it is subject to random collisions.
But I disagree that temperature is not defined for a non-equilibrium system. The fact that heat is flowing into or out of a system does not mean it has no temperature. A cooking turkey, for example is not in thermal equilibrium. It still has a defined temperature and if you stick a thermometer probe into it while it is cooking, you can measure it.
AM
KE = 3/2 kT​
Q_Goest:
Yes,u can bring into discussion temperature only in equilibrium states,or in states not far from the equlilibrium states.That T in the eq.
[tex]T=\frac{2}{3}\frac{E}{k}[/tex]
is the same temperature with the one dicussed in the thermodynamics of equilibrium processes.It is called KINETIC TEMPERATURE AND IS DENOTED BY
[tex]\Theta =:\frac{2}{i}\frac{E}{2}[/tex]
.However,because this kinetic temperature,in the case of statistical systems in equilibrium,coincides with the absolute termodynamic temperature (denoted by T and measured in Kelvin),it is denoted like the latter,viz.with T.
Temperature is a statistical quantity.That's because entire thermodynamics of reversible/equilibrium processes (in either formulation,but the neogibbsian is more easy to use) contains the same results as a subtheory of statistical physics of equlibrium processe called 'statistical thermodynamics'.
In the neogibbsian formulation of thermodynamics,temperature is defined implicitely by:
[tex]\frac{1}{T}(U,\{X_{i}\})=:(\frac{\partial S(U,\{X_{i}\})}{\partial U})_{\{X_{i}\}[/tex] (1)
,which is bsically the same with its definition within the microcanonical ensemble (classical or quantum) of statistical mecanics of equilibrium processes:
[tex]\frac{1}{T}(E,\{X_{i}\})=:(\frac{\partial S(E,\{X_{i}\})}{\partial U})_{\{X_{i}\}[/tex] (2)
,where E is the value of the Hamiltonian,assumed fixed at macroscopical level.It is actually the internal energy from thermodynamics.
Daniel.
As was stated, temperature is a statistical quantity. If you try to attach T to individual particles (actually, degrees of freedom not particles), you'll get widely differing results and no useful quantity. But large numbers of particles do have a temperature. The number of particles needed for a useful quantity is related to how much "noise" you can tolerate. If you want a temperature correct to 1%, you only need about 10,000 particles. (Noise ~ 1 / square root of N) This is quite a small number on macroscopic scales of 10^24 particles. So though your teacher may be correct in some sense, it requires a measurable temperature gradient across a volume containing only some 10,000 particles before we can say the medium is too far from equilibrium to define a temperature.
  • · Replies 135 ·
10K
13K
