New Reply
Burst test calculation help
Share Thread Thread Tools
Mar14-12, 07:44 AM   #1
Not really a homework question, but it could be. Working on making a burst test chamber and need some calculations that says it is safe enough. Sorry for my poor english, it's not my first language.
The setup: First a brass fitting would be fitted inside a chamber, and then pressurize until burst. I would like to know how much stress the bursting object gives to the surface of the chamber.
My current numbers:
Fitting weight: 202grams.
Pressure: 150bar (=15000kPa)
Diameter inside the pressurehose: 15.23mm
Length to nearest surface: 5cm
Length to bottom of chamber: 15cm
Do I/you need more numbers?
How thick stainless steel plate will I need so the 202gram object pressurized at 150bar won't give dents?
Thank you!
2. Relevant equations
P=F/A
3. The attempt at a solution
Not sure....
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
New Reply
Thread Tools
Similar Threads for: Burst test calculation help
Thread Forum Replies
burst operation Electrical Engineering 0
burst of 40Khz Engineering Systems & Design 2
how do we tell how far away a gamma burst was? General Astronomy 10
Gamma ray burst General Astronomy 17
