| New Reply |
Do elemental peaks on SEM-EDS spectra relate to concentration |
Share Thread | Thread Tools |
| Mar14-12, 05:07 PM | #1 |
Hello,
I recently did an experiment where I examined and analyzed crystals using SEM-EDS. One of the major parts of my experiment was to determine the concentration of a certain element (calcium) in the different crystal samples. I noticed that some calcium peaks were higher than others. Does this relate to concentration at all? Thanks |
| Mar15-12, 04:19 PM | #2 |
EDS spectrum analysis can be notoriously difficult when you want quantitative results. Do a search on 'quantitative EDS' - lots of things to learn about.
The short of it is that you typically want to use a spectrum with good signal to noise ratio, collected with a sampling rate that minimizes various sampling errors, and quantitate the spectrum using ZAF correction factors using standards whose compositions are accurately determined using other techniques. Generally speaking, it's very difficult to get results within 20% accuracy, and often the results can be off by much larger factors. |
| New Reply |
| Tags |
| analytical chemistry, sem-eds, spectra, spectral analysis, spectroscopy |
| Thread Tools | |
Similar Threads for: Do elemental peaks on SEM-EDS spectra relate to concentration
| Plasma & the elemental table | General Physics | 1 | ||
| Elemental composition of the body | Chemistry | 5 | ||
| Why do ions flow from high concentration to low concentration? | General Physics | 2 | ||
| identify peaks in spectra | Programming & Comp Sci | 4 | ||
| Spectra of small molecule and computed spectra | Biology, Chemistry & Other Homework | 2 | ||
