What is the Proof for Kinetic Energy in a Circular Magnetic Field?
The discussion revolves around proving the relationship between kinetic energy and the radius of curvature for a charged particle moving in a circular path within a magnetic field. The subject area includes concepts from electromagnetism and classical mechanics.
  • Participants explore the relationship between kinetic energy and radius of curvature, questioning how to derive one from the other using relevant equations. They discuss the implications of substituting values and the significance of resulting identities.
Some participants have provided insights into manipulating equations to express kinetic energy in terms of radius. There is an ongoing exploration of how to relate these quantities, with various interpretations being considered. A few participants express confusion about the steps involved, while others attempt to clarify the relationships.
Participants note the challenge of deriving the relationship without losing track of variables and constants, particularly in the context of changing velocities. There is an acknowledgment of the foundational material being reviewed, suggesting a familiarity with the concepts involved.
joej
this should probably go in the HS section since it is review of some material covered there but... I'm guessing the same peole brose the two forums so I might as well post it here since it came up in college.
now the questions seems quite straight forward:
for a particle of mass m and charge q, moving in a circular path in a magnetic field B, show that its kinetic energe is proportional to the square of the radius of curvature of its path.
so we have:
r = (mv^2)/qvB
r = mv^2/F
F = ma
F = m((v^2)/r)
r = (mv^2)/(m((v^2)/r))
now... it all evens out and I'm stuck with nothing... could someon tell me where I'm going wrong with this
When you get a result like 1 = 1 or r = r, it means you're substituting an equation into itself, which should naturally take you nowhere.
--J
1.Do you know the expression of KE in terms of velocity??
2.Can u compute/find a relation between the radius of trajectory and the velocity the particle has...?
Daniel.
KE = 1/2 mv^2
yeah I know that
still don't see how I can go from r = (mv^2)/F to r^2 = 1/2 mv^2
joej said:
KE = 1/2 mv^2
yeah I know that
Can u prove that:
[tex]r_{traj.}=\frac{mv}{qB}[/tex]
Daniel.
so we have:
r = (mv^2)/qvB
This is all you need. As well as KE=1/2 mv^2
Use the two equations you've got:
r=(mv^2)/qvB and
KE=1/2mv^2
to get a relationship between KE and r.
r=(mv^2)/qvB and
KE=1/2mv^2
Forgive my thickness but I can't figure out how to go from those two to proving that (r^2) is proportional to (1/2 mv^2)
dextercioby said:
Can u prove that:
Daniel.
well yeah that's just the v at the bottom is canceled out by v^2 and the square is thus also gone, but where do I go from there
If u can prove that,it means u can prove it is valid even when it's squared:
[tex]r_{traj.}^{2}=\frac{m^{2}v^{2}}{q^{2}B^{2}}=\frac{2m}{q^{2}B^{2}}\frac{mv^{2}}{2}=C\cdot (KE)[/tex]
Voilà.
Daniel.
Taking your first equation
r=(mv^2)/qvB
if I solve for v I get
v=rqB/m
Then I plug it into the KE equation
KE=(1/2)mv^2
[tex]KE=\frac{1}{2}m(\frac{rqB}{m})^2[/tex]
[tex]KE=\frac{q^2B^2}{2m}r^2[/tex]
since [tex]\frac{q^2B^2}{2m}[/tex] is a constant, this proves KE is proportional to r^2.
You needed an expression for KE in terms of r, and constants (v is not a constant here as it changes with r), so you needed to get rid of that v... so solve for v in the first equation and plug it into the second... so all that is left is constants and r's.
ah okay I finally get it thnx to both of you, great help, really appreciate it ;)
