Understanding the copenhagen interpretation
The discussion revolves around the Copenhagen interpretation of quantum mechanics, specifically focusing on the mathematical representation of states and the inner product in Hilbert space. Participants explore the implications of these concepts in the context of quantum mechanics, including the nature of wavefunctions and their relation to states.
  • One participant notes that the integral (ψ, φ) = ∫ d³r ψ*(r) φ(r) represents an inner product in a Hilbert space, questioning its specific meaning.
  • Another participant suggests that a higher value of the inner product indicates a greater relationship between the two states, leading to similar eigenvalues upon measurement.
  • Some participants clarify that a wavefunction is not synonymous with a state, as a state can be represented in various bases, with the wavefunction being a specific representation.
  • A participant explains that the inner product is related to the probability of measuring a system in one state after it has been prepared in another state.
  • One participant expresses frustration about the perceived lack of qualifications among respondents, while others assert that many participants are indeed qualified to discuss the topic.
  • Another participant emphasizes the importance of the semi-inner product in calculating probabilities in quantum mechanics.
  • It is mentioned that the integral can represent the overlap between two wave states and is used in transforming between bases.
Participants express differing views on the definitions and implications of wavefunctions and states, with some clarifying concepts while others challenge the understanding presented. There is no consensus on the interpretation of the integral or the nature of states and wavefunctions.
Some participants highlight the complexity of the definitions and relationships in quantum mechanics, indicating that assumptions about terminology may lead to confusion. The discussion reflects varying levels of understanding and interpretation of foundational concepts.
This discussion may be useful for students and enthusiasts of quantum mechanics seeking to understand the Copenhagen interpretation and the mathematical framework underlying quantum states and measurements.
spaghetti3451
This is an extract from the lecture notes I took for the 'Foundations of QM' third year course.
Copenhagen QM - classical-quantum division
State: wavefunction ψ(x); (ψ,[itex]\varphi[/itex]) = [itex]\int d^{3}r ψ^{*}(r)\varphi(r)[/itex]
Evolution: TDSE
Observables ([itex]\hat{x},\hat{p},\hat{H}[/itex]): A = A-dagger; {x,p} = 1 [itex]\rightarrow[/itex] [itex][\hat{x},\hat{p}][/itex] = i[itex]\hbar[/itex]
Probability: [itex]\left|ψ\right|^{2}d^{3}r[/itex] Born rule
Measurement: collapse of ψ - can't assume system possesses properties if not measured
Composite systems: [itex]ψ_{AB} (x_{1},x_{2}) = ψ_{A} (x_{1}) ψ_{B} (x_{2})[/itex] if uncorrelated
I am wondering what (ψ,[itex]\varphi[/itex]) = [itex]\int d^{3}r ψ^{*}(r)\varphi(r)[/itex] means and why it is shown under 'state'.
Any help would be greatly appreciated.
Okay, let me give you a headstart. The integral represents an inner product in a Hilbert space. Question is what exactly does it represent.
I am wondering if you could be more specific.
The closer the inner product to one, the greater the two states are related to each other, that is, operators acting on them will return the same eigenvalue with higher and higher probabilities. Is that it?
I am beginning to wonder if no one on Physicsforums has the necessary qualifications to answer my question.
The answer is simple. It doesn't show up under 'state', only $\psi(x)$ shows up under 'state'. Your confusion comes from the way you take notes.
can any one explain ? copenhagen interpretation ? and others simply :)
I'm not sure what your question is, the copenhagen interpretation is nothing more than an interpretation
A state is not a wavefunction, a wavefunction is a state in some basis, usually the position basis.
State: wavefunction ψ(x); (ψ,φ) = ∫d3rψ∗(r)φ(r)
A wavefunction is indeed a [itex]\psi (x)[/itex], this is not a state however
A state is [itex]|\alpha \rangle[/itex], it is related to a position wavefunction by [itex]\psi(x) = \langle x | \alpha \rangle[/itex]
The '(ψ,φ) = ∫d3rψ∗(r)φ(r)' part is just the definition of the inner product. The inner product in this picture is the probability of a system being prepared in state φ, after being measured being found in state ψ. (well, it's the mod squared of this that's the probability really)
If you take a simple example with two orthogonal states a,b then we have (A,B) = 0. We can prepare our system in a state S=c(A+B) where c is a normalisation constant, then we'd have (A,c(A+B)) = c(A,A)+c(A,B) = c, so the probability of finding our system S in a state A after measurment is |c|^2.
You shouldn't be throwing around stuff like that, you're question has already been answered by two other people.
can anyone explain ? copenhagen interpretation ? and others simply :) [/QUOTE
http://en.wikipedia.org/wiki/Interpretations_of_quantum_mechanics
Obviously, a lot of people here are more than qualified.
The set of wavefunctions is a vector space, let's call it V, and the map from ##V\times V\to\mathbb C## that you defined is a semi-inner product on that space. The pair (V,the map you defined) is a semi-inner product space.
The semi-inner product is as important as the wavefunctions, since you use it to calculate probabilities. For example, when you perform a measurement of A on each member of a large collection of systems that have all been prepared in a way that's consistent with the wavefunction ψ, QM predicts that the average result will be (ψ,Aψ).
This represents how much overlap there is between these two wave states. Typically, you would have an expression like this if you are converting from one basis to another and you want to calculate elements of the transformation matrix. If your initial state is given by |ψ>, then [itex]abs(\int d^{3}r ψ^{*}(r)\varphi(r))^2[/itex] gives you the probability of measuring it in the other state. Maybe this isn't what you wanted to know, but then you need to learn to ask better questions.
  • · Replies 33 ·
  • · Replies 47 ·
  • · Replies 35 ·
  • · Replies 21 ·
  • · Replies 34 ·
  • · Replies 76 ·
  • · Replies 21 ·
