Register to reply
Flux Linkage - what, where, why?
by lntz
Tags: flux linkage
Share this thread:
lntz
#1
Mar16-12, 05:33 AM
P: 53
Hi,
we have been doing lots of work recently on magnets. we have learnt about the ideas of flux, and using them to describe induction and how transformers work etc.
i feel that i understand quite well about these ideas, but now i have come across this idea of 'flux linkage'.
i do not understand what this is. the definitions i have been reading don't seem very explicit.
so please can somebody explain to me what it is, and why the ideas are important/useful.
thanks in advance.
Phys.Org News Partner Physics news on Phys.org
Physicists discuss quantum pigeonhole principle
First in-situ images of void collapse in explosives
The first supercomputer simulations of 'spin?orbit' forces between neutrons and protons in an atomic nucleus
tiny-tim
#2
Mar16-12, 09:09 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,160
hi lntz!
a major difficulty in understanding magnetic flux linkage is that it has the same units as magnetic flux (Wb)
if there are N turns of wire round an area A, through which there is a magnetic field B at an angle θ,
then the magnetic flux through A is Φ = BAcosθ,
and the magnetic flux linkage through A is NΦ = NBAcosθ
the only difference is the number of turns, N, which has no units!
i find this easier to understand if we use the H field (instead of the B)
the H field is magnetic moment density, measured in amp-turns per metre (A/m)
the H flux is magnetic moment per length, measured in amp-turn-metres (Am)
eg if the magnetic field is produced by a primary solenoid with current I area A length L and turns N (and pitch n = N/L),
then H = nI amp-turns per metre (independent of A)
and H flux = nIA = NIA/L amp-turn-metres
if this flux then goes through a secondary solenoid with the same area and M turns,
the flux linkage is M times the flux, = MNIA/L amp-turn2-metres
returning to the B field (where the concept of "turn" as a unit is unnatural ):
B = µH = µnI
B flux (from the N-turn primary) = µNIA/L webers
B flux linkage (through the M-turn secondary) = µMNIA/L webers
technician
#3
Mar16-12, 03:50 PM
P: 1,506
I agree with Tiny tim reference to number of turns, N,
If you have one turn of area A in a magnetic flux density of B tesla (webers/m^2) then the flux phi = B*A webers.
If there are N turns then the effective flux is N times greater = NBA
This is called magnetic flux linkage
Register to reply
Related Discussions
Flux Linkage through two coils Introductory Physics Homework 0
Flux linkage vs. flux, Faraday's/Lenz's Law Introductory Physics Homework 0
Flux Linkage with a coil in a solenoid Introductory Physics Homework 1
Magnetic Flux Linkage Advanced Physics Homework 1
Magnetic flux linkage Introductory Physics Homework 6
