Magnetic Field of a Moving Point charge
The magnetic field produced by a moving point charge of 3.6 nC, traveling at a speed of 4.5 x 107 m/s parallel to the y-axis, at the origin when located at (3 m, 4 m) is calculated using the Biot-Savart Law. The correct cross product of the velocity vector and the position vector yields a magnetic field vector of approximately 0.39 nT in the positive z-direction. The magnetic constant used in the calculation is 4π x 10-7 (Tesla x meter)/Ampere. The final magnetic field value is derived from the formula vector B = (magnetic constant/4π) (q(vector v X unit vector r)/r2).
  • Understanding of the Biot-Savart Law
  • Familiarity with vector cross products
  • Knowledge of magnetic fields and point charges
  • Basic calculus for vector magnitudes and unit vectors
  • Study the Biot-Savart Law in detail
  • Learn about vector calculus and cross product applications
  • Explore magnetic field calculations for different charge configurations
  • Investigate the implications of charge motion on magnetic field direction
Physics students, electrical engineers, and anyone interested in electromagnetism and magnetic field calculations related to moving charges.
OmegaFury
A point charge of q1=3.6nC is moving with speed 4.5 x 107m/s parallel to the y-axis along the line x=3m. The magnetic field produced by this charge at the origin when it is at the point x=3m, y=4m is approximately:
vector B= (magnetic constant/4pi) (q(vector v X unit vector r)/r2)
magnetic constant= 4pi x 10-7 (Tesla x meter)/Ampere
The problem here is a curious cross product outcome.
vector v= 4.5 x 107j = <0, 4.5 x 107, 0>
vector r= <3-0, 4-0, 0-0>= <3,4,0>
magnitude of r= sqrt(32+42)= 5
unit vector r= vector r/ magnitude of vector r= <3,4,0>/5
[itex]\vec{v}[/itex]X[itex]\hat{r}[/itex]= <0, 4.5 x 107, 0> X <3, 4, 0> =
((4.5 x 107(0) - 0(4))i - (0(0) - 0(3))j + (0(4) - 4.5 x 107(3))k)/5 =
(-13.5 x 107j)/5= <0, 0, -13.5 x 107>/5
Wouldn't that imply that the cross product vector is in the -Z direction? However, using right hand rules, shouldn't the cross product vector be in the positive Z direction?
Welcome to PF.
In the Biot Savart Law, the direction of r is from the current element or charge to the point where B is being calculated. So r is <-3,-4,0> in this case.
p.s. I presume the charge is moving in the +y direction?
Redbelly98 said:
Welcome to PF.
Ahhhhh. So I had it reversed.
Yes, the charge is moving in the +y direction.
So the cross product would now be: <0, 4.5 x 107, 0>m/s X <-3, -4, 0>/5 =
(0--(3/5)(4.5 x 107)) k= +2.7 x 107m/s k
Then vector B= (magnetic constant/ 4pi) (3.6 x 10-9C)(2.7 x 107m/s k) / (25m2)= 3.89 x 10-10 T k. Which is equal to 0.39nT k
Thank you for your assistance :)
