matematikuvol
- 190
In thermodynamics heat reservoir has a lot deegres of freedom. Can you tell me some examples of that deegres. Thx
The discussion revolves around the concept of degrees of freedom in thermodynamics, particularly in relation to heat reservoirs and their microscopic properties. Participants explore how degrees of freedom apply to different types of gases and the implications for thermodynamic systems.
Participants express differing levels of understanding regarding the application of degrees of freedom in thermodynamics, with no consensus reached on the initial question posed. Some participants provide clarifications, while others remain uncertain about the connection to heat reservoirs.
The discussion highlights the complexity of applying mechanical concepts of degrees of freedom to thermodynamic systems, with unresolved assumptions about the definitions and implications of these terms.
Thermodynamics uses "degrees of freedom" in the same sense the term is used in mechanics.matematikuvol said:In thermodynamics heat reservoir has a lot deegres of freedom. Can you tell me some examples of that deegres. Thx
