What is the outcome of mixing these two chemicals
  • Thread starter Thread starter mingloo
    Chemicals Mixing
The discussion revolves around the potential outcomes of mixing two cleaning chemicals: Sodium Dichloroisocyanurate and Sodium Dodecylbenzene sulfonate. Participants explore the effectiveness and safety of this mixture in a cleaning context.
  • One participant expresses concern that mixing the two chemicals could produce a dangerous gas.
  • Another participant suggests that the chemical structures of the two compounds appear unreactive with each other.
  • A different view proposes that the mixture may enhance cleaning effectiveness due to the surfactant properties of Sodium Dodecylbenzene sulfonate and the stabilizing effect of Sodium Dichloroisocyanurate.
  • It is noted that Sodium Dichloroisocyanurate releases small amounts of chlorine, which may not react significantly with the alkane sulfonate, suggesting no harmful gas is produced.
  • Some participants argue that the combination could be more effective for disinfecting, although it may not noticeably improve cleaning grease or grime.
Participants express differing opinions on the safety and effectiveness of mixing the two chemicals. While some believe it is safe and potentially more effective, others remain concerned about possible dangers.
Participants do not fully resolve the question of safety or effectiveness, and there are varying interpretations of the chemical interactions involved.
mingloo
At work we use;
Powder Bleach, ACTIVE INGREDIENT: Sodium Dochloroisocyanurate
and
A cleaning agent, ACTIVE INGREDIENT: Sodium Dodecylbenzene sulfonate
These two chemicals are to be used separately but we have the sudden rumour that when mixed in a mop bucket it is significantly more effective than using just the Sodium Dodecylbenzene Sulfonate. I entirely disagree, suggesting that the mixture of the two could produce a dangerous gas.
Can anyone help me to discover the outcome of mixing these two chemicals?
Thanks!
Chemistry news on Phys.org
Looking at their structures, they seem to be unreactive with each other.
mingloo said:
At work we use;
and
Thanks!
won't produce anything. in general 2 large anions (Na+ is not active) will not react. it may be more effective because one is a surfactant and the other somehow stabilizes the surfactant emulsions.
The dichloroisocyanurate is a compound that continuously releases small amounts of chlorine and the alkane sulfonate is a detergent. Using them together are more effective than using them separately for disenfecting. You probably wouldn't notice anything special about the mix's ability to clean grease or grime but it will certainly make a better cleaner/disenfecting solution. This form of chlorine is not very reactive with the alkane sulfonate since the chlorine it produces is always in fairly low amounts.
No gas when you mix these two together.
  • · Replies 19 ·
11K
  • Sticky
  • · Replies 0 ·
74K
  • Sticky
45K
  • · Replies 36 ·
  • · Replies 21 ·
11K
