The gravition and Einstein's equivalence principal
  • Context: Graduate
  • Thread starter Thread starter StatusX
    Equivalence
The discussion revolves around the relationship between the graviton, a hypothetical particle mediating gravitational force, and Einstein's equivalence principle, which posits that no experiment can distinguish between an accelerated frame and a stationary frame under gravity. Participants explore whether the existence of gravitons contradicts or modifies the equivalence principle, and the implications of this for general relativity.
  • Some participants question whether the equivalence principle can hold if gravity is mediated by a particle like the graviton, suggesting that this could allow for distinctions between frames.
  • Others argue that the detection of gravitons is frame-dependent, which may not necessarily violate the equivalence principle.
  • A participant notes that the equivalence principle has been foundational to general relativity, raising concerns about its validity if it can be contradicted by the existence of gravitons.
  • Some contributions discuss the challenges of quantizing gravity and the implications of virtual particles in this context, suggesting that virtual gravitons may not be detectable in certain frames.
  • There is mention of string theory's predictions regarding gravitons and the complexities involved in reconciling these with classical gravitational theories.
  • Participants express confusion about the definitions and properties of particles, particularly in relation to real and virtual particles and their detectability in different frames.
  • Some participants propose that if no gravitons can be detected in a free-falling frame, this might be a resolution to the conflict, while others remain uncertain about the implications of this scenario.
Participants do not reach a consensus on whether the existence of gravitons contradicts the equivalence principle. Multiple competing views remain regarding the implications of graviton detection and the validity of the equivalence principle in light of quantum theories.
There are unresolved issues regarding the definitions of particles, the nature of virtual particles, and the implications of coordinate transformations on the detectability of gravitons. The discussion reflects a range of assumptions and interpretations of theoretical frameworks.
StatusX
the graviton and einstein's equivalence principle
Einstein's theory of general relativity was motivated by his equivalence principle, that no experiment can distinguish between an accelerated frame and a still frame under the influence of gravity. But if the gravitational force is mediated by a particle, the graviton, then couldn't they be distinguished? (if there are no gravitons, you are accelerating) So has this equivalence principle been abandoned, or is it still somehow true?
I wrote a text on this in my journal. Just look for string theory part 1...
regards
marlon
just click on "read my journal" under my name...
https://www.physicsforums.com/journal.php?s=&action=view&journalid=13790&perpage=10&page=2
here is the link
just look into string theory part one and go to the subsection General Relativity
regards
marlon
If the experiment is done within a very tall box, then gravity will diminish with altitude, and acceleration will not.
I'm still confused. Marlon, your journal talked about GR, but I didn't see anything specifically mentioning this conflict. This may sound like a triviality, since principles change all the time (eg, conservation of energy became conservation of mass-energy when we saw they could be interchanged). But Einstein's whole theory arose because of this principle, and if it isn't ture, his theory seems to just become a huge coincidence.
I think the point you raise is one of the main arguments against the existence of the graviton in the first place. It still hasn't been discovered, and I doubt it will be
This is an interesting question. I know about the graviton as a hypothetic particle which results from quantizing a weak perturbation of the flat spacetime metric. The perturbation is quantized in the same way than other quantum fields are quantized on flat spacetime. This procedure is called covariant quantization and I think it is not regarded as very successful, because it considers the gravitational interaction only perturbatively. However, as far as I know string theory claims to fully contain classical gravitation and it does also predict a graviton. And this is somehow puzzling, because in case of an uniform gravitational field a coordinate transformation should remove every graviton. But I am not sure this is really as weird as it seams, since the gravitons which need to be removed by a coordinate transformation (the gravitons responsible for the gravitational interaction) would be virtual gravitons and not real ones. Well, I do not know the answer to your question and whether there is one.
Another argument against the existence of the graviton is that the gravitational field (boson=graviton) and the Higgs field (with its theoretical Higgs bosons) are required to be excruciatingly concordant everywhere and everywhen all over the visible Universe. If they were not so concordant, we would see objects in different parts of the universe acting in odd ways as "local" gravitational effects caused objects to more or less gravitationally attractive. Gravity seems to follow the same rules everywhere and everywhen we look, so this is a strong indicator that mass, gravitation, and inertia all arise from matter's interaction with a single field, not from two separate fields, one of which conveys mass and the other of which mediates gravitational attraction.
That would be my guess too...virtual particles are just things that show up in the equations you use to predict how "real" particles behave, they aren't detectable by experiment (see section s3 of http://arnold-neumaier.at/physics-faq.txt, especially question s3c). I would think that gravitons could only be detected directly in a situation where gravitational waves are passing by you (gravitons being the quanta of gravitational waves just like photons are the quanta of electromagnetic waves--see section 5 of this FAQ on virtual particles), but as I understand it the equivalence principle only deals with arbitrarily small regions of spacetime where things like tidal forces and gravitational waves can be ignored.
Well, it was just a thought but I guess this cannot be the solution. There is a definition of particle which is valid for real particles as well as for virtual particles. I think the question is what happens with gravitons in accelerated reference frames and how to model the fictious force in an uniform gravitational field. I would say it makes no sense to say that the contributions of virtual particles can be transformed away by the coordinate transformation whereas any real particle will remain invariant. It seams to be a very tricky issue, at least I am completely lost...
No. The ability to detect the graviton is a frame dependent phenomena. Also you stated the EP wrong. It states
Einstein's Equivalence Principle (weak form) - It is impossible to determine whether you're in a static uniform gravitational field or a unifornly accelerating frame of reference.
Einstein's Equivalence Principle (strong form) - The laws of physics are the same in all coordinate systems. Mathematically this means that one must always be able to express the equations of physics in tensor form. This holds whether the gravitational field is uniform or notl
Pete
What definition are you talking about? My point is just that you cannot detect virtual particles experimentally--do you disagree? Did you read the section on virtual particles from the http://arnold-neumaier.at/physics-faq.txt I mentioned?
Particles are usually defined according to their properties preserved during isometries in flat spacetime.
I do not disagree with you, I was just arguing against me (the part of my post you cited above). Sorry for the confusion.
But the graviton is usually defined to be a particle described by a second rank tensor. How can this be frame dependent?
But what did you mean when you said this cannot be the solution? If no gravitons will be detectable in an elevator falling through a gravitational field, isn't that a solution of sorts, since the experimenter won't see anything different than if the elevator was moving inertially in deep space?
You may consider that gravitons can be transformed away by a coordinate transformation to a free falling frame. Or you may not. Both possibilities must treat real and virtual gravitons in the same manner. If gravitons cannot be transformed away in a free falling frame, then virtual gravitons will contribute to the transition amplitudes in the gravitational interaction. It does not help that they are not measurable.
This principle has many formulations but don't forget it is only valid locally. Locally means in a region of spacetime that is very small and therefore has a flat metric where the laws of SR apply.
If you are talking about gravitons and forces of gravitation then you are not talking about GR but some alternate theory. Gravitons require a quantum theory of gravitation which has not yet been formulated in general.
OK, are you saying that even if individual gravitons are not detectable, they could "contribute to the transition amplitudes in the gravitational interaction" in such a way that a person inside a small windowless elevator could do some experiment involving gravity that would tell him he was falling through a gravitational field rather than moving inertially in free space? If so, what type of experiment might yield different results in these two cases? (assume the experimenter has the technology to do any possible experiment allowed by the laws of physics, however unfeasible it may be by present-day standards)
  • · Replies 44 ·
  • · Replies 33 ·
  • · Replies 18 ·
