Snell's Law, indices of refraction
The problem involves a beam of light transitioning through a series of transparent materials with different indices of refraction, specifically applying Snell's Law to determine the angle of emergence back into air after passing through the materials.
  • Participants discuss the application of Snell's Law, questioning how to set up the equations with the given indices of refraction and angles. There is uncertainty about the correct values for n1 and θ1, as well as how to handle the angles through each layer.
Some participants have suggested using a specific version of Snell's Law to work through the layers, while others are exploring the implications of light entering and exiting parallel-sided materials. There is a recognition that the angle of emergence may equal the angle of incidence under certain conditions.
Participants are navigating the problem with the assumption that the materials have parallel sides, which influences the behavior of light as it enters and exits the stack. There is also a mention of the angle of incidence being 60 degrees, which is a key aspect of the problem setup.
monke
A beam of light in air is incident on a stack of 4 flat transparent materials with indicies of refraction 1.20, 1.40, 1.32, and 1.28. If the angle of incidence for the beam on the first of the four materials is 60*, what angle does the beam make witht the normal when it emerges into the air after passing through the entire stack?
what is the best way to start and understand this type of problem?
Do I just use Snell"s Law and use the incides of refraction of air for n sub i and 60 for theta sub i?
Thanks in advance :)
A good exercise in this question is to use this version of snell's law:
n1Sinθ1 = n2Sinθ2 and apply this as you work through each layer.
You will get an answer that may surprise you.
Once you get this answer it will reveal something about light entering and leaving parallel sided blocks.
okay what do i use for the n1 sinθ1? is that 60* and the n for air =1.000?
then do i just add all the thetas together?
oh i think i got it you use n=1.00 sin60= 1.20sin theta 1 and then solve for theta 1 and sub in all down the layers until you use n=1.00 and solve for theta i. the angle is the same going out of the layers as it was going in?
That is it.
If the block has parallel sides the light emerges at the same angle it entered.
That is it.
32K
