Why Can't Yeast Survive High Concentrations of Ethanol in Fermentation?
In summary, the yield of ethanol depends on the survivability of the yeast. This is because high concentrations of ethanol can denature the proteins in the yeast, leading to its death. Alcohol denatures proteins by disrupting the side chain intramolecular hydrogen bonding and forming new bonds with the protein side chains. Proteins also rely on hydrophobic interactions, and in the presence of ethanol, these interactions are disrupted, causing the proteins to unfold and lose their function. The more pure the ethanol is, the weaker the interactions between non-interacting regions of the proteins, leading to their unfolding. This is why adding more water to the solution can increase the yield of ethanol, as it dilutes the alcohol and reduces its ability to denature proteins
dazza95
35
Yield of ethanol is mostly about survivability of the yeast.
We were wondering why Yeast can't survive too high concentrations of ethanol?
Something to do with the denaturation of proteins?
Not really sure on this, any help is appreciated
Thanks
Chemistry news on Phys.org
I don't know much about this but your answer seems to make sense.As time passes the rate of fermentation seems to die down due to, I'm guesssing,the enzyme proteins becoming less active and tending towards denaturing.Enzymes can be sensitive to temperature and PH and in this case,I assume to ethanol concentration as well.
Here are some notes we gathered, does any of it make sense. Or is any of it a reasonable explanation?
A 62% ethanol solution is used as a disinfectant on the skin. This concentration of alcohol is able to penetrate the bacterial cell wall and denature the proteins and enzymes inside of the cell. A 95% alcohol solution merely coagulates the protein on the outside of the cell wall and prevents any alcohol from entering the cell. Alcohol denatures proteins by disrupting the side chain intramolecular hydrogen bonding. New hydrogen bonds are formed instead between the new alcohol molecule and the protein side chains.
Proteins depend heavily on "hydrophobic" interactions
Water molecules like to form strong hydrogen bonds with each other, if there's a large surface area of protein in the solution, these interactions are disrupted. In order to minimise exposed surface area, the bits of the protein which aren't able to interact with each other tend to fold over themselves to minimise exposed surface area.
It's basically the same reason oil and water don't mix.
In ethanol, however, the tendency for non-interacting regions to stick together is much weaker so proteins tend to unfold.
The more water that is added, the more pure the ethanol is because it denatures protein too quickly and forms a thin outer layer of denaturated protein beyond which the cell lives on.
Don't worry about the above post,
we have refined it down to this explanation, not sure if it is entirely correct,
Water molecules like to form strong hydrogen bonds with each other, if there's a large surface area of protein in the solution, these interactions are disrupted. In order to minimise exposed surface area, the bits of the protein which aren't able to interact with each other tend to fold over themselves to minimise exposed surface area. In like a ball or coil.
The more pure the ethanol is, the tendency for non-interacting regions to stick together is much weaker so proteins tend to unfold.
Too much alcohol = dead yeast.
Hydrogen bonds cause the tertiary structure (ethanol) to stuff up. Only one hydrogen bond needs to stuff up and the whole process is over and the yeast dies.
Thank you for your question. The survivability of yeast during fermentation is indeed a crucial factor in the yield of ethanol production. Yeast is a type of microorganism that plays a central role in the fermentation process by converting sugar into ethanol and carbon dioxide. However, as you mentioned, yeast has a limited tolerance for high concentrations of ethanol, and this can significantly impact its survival and ability to produce ethanol.
The main reason for this is the denaturation of proteins. Ethanol is a solvent that can disrupt the structure and function of proteins, which are essential for the yeast's survival and fermentation activity. As the concentration of ethanol increases, it can cause the proteins to unfold and lose their shape, rendering them unable to carry out their biological functions effectively.
Additionally, high concentrations of ethanol can also lead to changes in the cell membrane of the yeast, making it more permeable and disrupting its ability to maintain proper internal conditions. This can further impact the yeast's survival and ability to produce ethanol.
To ensure the survival of yeast during fermentation, it is essential to maintain a suitable environment with optimal levels of ethanol and other nutrients. This can be achieved by carefully monitoring and controlling the fermentation process, allowing for the yeast to thrive and produce the desired amount of ethanol.
I hope this helps to answer your question. If you have any further inquiries, please do not hesitate to reach out. Thank you.
1. What is yeast and why is it important in the fermentation process?
Yeast is a single-celled microorganism that is used in the fermentation process to convert sugars into alcohol and carbon dioxide. It is an essential ingredient in the production of beer, wine, and bread.
2. How does yeast contribute to the flavor and aroma of fermented products?
During the fermentation process, yeast produces various byproducts such as esters and alcohols, which give fermented products their unique flavors and aromas. Different strains of yeast can also produce different flavors and contribute to the complexity of the final product.
3. Can different types of yeast be used in the fermentation process?
Yes, there are many different strains of yeast that can be used in the fermentation process. Each strain has its own unique characteristics and can produce different flavors and aromas. Some strains are better suited for specific types of fermentation, such as ale or lager yeast for beer production.
4. What factors can affect the growth and activity of yeast in the fermentation process?
The growth and activity of yeast can be affected by several factors, including temperature, pH levels, and the availability of nutrients. Yeast also requires oxygen to grow, but too much can inhibit its activity. The type and amount of sugar used in the fermentation process can also impact yeast growth and activity.
5. Is yeast necessary for all types of fermentation?
No, while yeast is commonly used in the fermentation process, there are some types of fermentation that do not require yeast. For example, some types of fermentation for dairy products and vegetables rely on lactic acid bacteria instead of yeast. Additionally, some fermented products, such as kombucha, use a combination of yeast and bacteria for fermentation.
14K
16K
13K
  • Other Physics Topics
  • Biology and Medical
