Covert to Watts, Input and Output Values provided, Covert it to Watts
The discussion focuses on calculating the wattage of a Sony laptop charger based on its specifications. The output voltage is 19.5V with an output current of 4.7A. Using the formula for DC power, the output wattage is determined to be 91.65W (calculated as 19.5V multiplied by 4.7A). The input specifications indicate a range of 100-240V and 1.3A, confirming the charger's versatility across different power sources.
  • Understanding of electrical concepts such as voltage, current, and power.
  • Familiarity with the formula for calculating power in DC circuits (P = V x A).
  • Knowledge of AC and DC power specifications.
  • Basic understanding of laptop charger specifications.
  • Research the efficiency of laptop chargers and how it affects power consumption.
  • Learn about the differences between AC and DC power specifications.
  • Explore the impact of charger heat on performance and efficiency.
  • Investigate how to measure actual power consumption using a wattmeter.
Electronics enthusiasts, laptop users, and anyone interested in understanding power consumption and efficiency of laptop chargers.
raokhan
I have this Sony Laptop, the adapter has the following specifications:
These are the input and output values of laptop charger.
19.5V written in bold on top
Input:100-240V~1.3A 50-60Hz
Output: 19.5V---4.7A, the dotted line also has straight line above it, I don't know what's that symbol called, can someone help me in calculating how much watts it is?
welcome to pf!
hi raokhan! welcome to pf! :smile:
~ (as you know) means AC, and that no-overtaking double-line means DC :wink:
for DC, power (in watts) = volts times amps (W = VA),
so in this case the output power is 19.5*4.7 W :smile:
(but i don't know how much extra power is consumed by the charger itself :confused: … chargers can get rather warm!)
12K
11K
  • · Replies 28 ·
