What is the angular size of the moon as viewed from Earth's surface?
The discussion revolves around calculating the angular size of the moon as viewed from Earth's surface, as well as through a refracting telescope. The problem involves understanding angular measurements and the relevant equations to apply in this context.
  • Participants explore the definition of angular size and its relation to the radius and distance of the moon. There are attempts to identify the appropriate equations for calculating angular size, with some participants questioning the use of radians and the application of specific formulas.
Participants are actively engaging with the problem, discussing various equations and their applications. Some guidance has been offered regarding the definition of angular size and its calculation, but there is no explicit consensus on the methods to be used for the specific questions posed.
There is a mention of the mean radius of the moon and its distance from Earth, which are relevant to the calculations. Additionally, participants are considering the implications of using a refracting telescope and how it might relate to the angular size calculations.
monke
a) what is the angular size of the moon as viewed from the Earth's surface?
b) The objective and eyepiece of a refracting telescope have focal lenghts 80cm and 2.0cm. What is the angular size of the moon as viewed though this telescope?
mean radius of the moon- 1.737x10^6m
mean distance from earth- 3.854x10^8m
Im not sure what equations to use or why the answer from the book is in radians
i tried using the equation m=near point/ object distace, with the near point being 25cm and object distace being the distance from the earth. HOwever the anwer from the book is in radians.
Thanks in advanced!
Of course the answer is in radians. It's asking you for the angular size. The angular size is defined as the angle subtended (spanned) by the object as seen by the observer. In other words, how big does it look? How much of your field of view does it take up?
What is the equation for an angle in terms of of the radius and the arc length (which you can equate to physical size)?
would that be theata= h (size of object)/N ( near point =25cm)?
No, I was just talking about the equation that gives you the definition of an angle (in the radian system)
i think i found it
theata = 2(radius)/disatance from the sun?
angle in terms of radians is
theta= s/r
(size of arc)/ radius
how should i have applied that to this particular question?
for the second part of the question, if a refracting telescope functions like a compound microscope does that mean that you would use the same angular equation?
M= -L/foX N/Fe
theta= s/r
Well, how big is the object? How far away is it? Therefore, what angle does it span? This is its angular (or apparent) size. That will get you the answer to part a.
