14 bits at the output means 16 bits -2 on the MSB side?
  • Thread starter Thread starter Femme_physics
    Bits Means Output
The discussion revolves around the interpretation of a 14-bit output in relation to a 16-bit input, specifically addressing how the bits should be connected and the implications of such connections. The scope includes technical explanations and interface considerations.
  • Some participants assert that 14 bits simply means 14 bits without additional implications.
  • One participant notes that in their older system, 14 significant bits were used within a 16-bit word, with the two most significant bits (MSBs) hardwired for sign representation.
  • Another participant suggests that when connecting 14 bits of output to a 16-bit input, the typical approach is to connect the 14 bits to the 14 least significant bits (LSBs), leaving the 2 MSBs unconnected.
  • A participant elaborates that the connection strategy depends on the expected range of values, indicating that mapping the MSB to MSB allows for maximum range but only 14-bit resolution.
  • Another participant raises a question about whether the confusion regarding 14 bits stems from an expectation of data being represented in two 8-bit bytes.
Participants express differing views on the implications of 14 bits in a 16-bit context, with no consensus reached on the best approach for connecting the bits or the interpretation of the bit significance.
The discussion highlights the dependence on specific device characteristics and the lack of clarity regarding the expected behavior of the 16-bit input when interfacing with a 14-bit output.
Femme_physics
Just trying to check myself, as 14 bits doesn't seem to make sense...so I want to see how does it make sense. Is what written at the title true?
14 bits means just 14 bits. You don't have to fight war for that.
I suspect it's device specific.
My old system(ca 1973) gave 14 significant bits in its 16 bit word, two MSB's were hardwired together and used for sign .
If you have to connect 14 bits of output to 16 bits of input, you would typically connect those 14 bits to the 14 least significant bits (lsb), leaving the 2 most significant bits (msb).
So yes, what you wrote at the title is true.
Seems simple enough-- thank you.
This is an interface question, I guess and the solution will depend upon the specifics.. If you have only 14 bits and want to connect to a 16 bit input then where you connect will depend upon what the 16 bit input ' expects' to receive. If you want 16 1s to be correspond to the maximum value that your 14 bits correspond to then you would need to connect MSB to MSB and put up with the coarser resolution. If the maximum value your 14 bit signal corresponds to 1/4 of the 16 Bit range, then you would connect LSB to LSB and accept the 1/4 reduction in range but the same resolution.
Or is your 'lack of belief' in 14 bits because you expected data to be in two 8bit bytes?
Where to connect the 14 bits to 16bits depend on the range you want. Usually for maximum range, you map MSB to MSB so you just map the 14MSB to the MS 14 bits of the 16 bit system. Then you just ground the LS 2 bits. With this, you get the full range of the 16 bit system BUT with only 14 bit resolution.
  • · Replies 22 ·
  • · Replies 18 ·
