Commutative finite ring and the Euler-Lagrange Theorem
The problem involves the ring Z/1026Z and its group of units G. The original poster attempts to demonstrate that g^{18}=1 for elements g in G, utilizing the Euler-Lagrange theorem and the Euler-phi function.
  • Participants discuss the properties of the group of units G and the implications of the Euler-phi function. Questions arise regarding the absence of elements of certain orders, particularly why no elements of order greater than 18 exist in G.
Some participants have provided insights into the structure of the group of units and the application of the Chinese remainder theorem. There is ongoing exploration of the implications of these structures on the orders of elements within G, with no consensus reached on the specific orders that can exist.
There is mention of the homework being due, indicating time constraints on the discussion. Participants are navigating through the implications of their findings and the correctness of their reasoning regarding the orders of elements in G.
Hugheberdt
We are given the ring [itex]Z[/itex]/1026[itex]Z[/itex] with the ordinary addition and multiplication operations. We define G as the group of units of [itex]Z[/itex]/1026[itex]Z[/itex]. We are to show that g[itex]^{18}[/itex]=1.
The Euler-phi (totient) function, here denoted [itex]\varphi[/itex](n)
I have verified that G is indeed a group and concluded that G contains all elements of [itex]Z[/itex]/1026[itex]Z[/itex] coprime to 1026.
I also know from the Euler-Lagrange theorem that since every g[itex]\in[/itex]G is coprime to 1026, g[itex]^{\varphi(1026)}[/itex]=1 (mod 1026).
[itex]\varphi(1026)[/itex]=18*18*2=648 [itex]\Rightarrow[/itex]
g[itex]^{18*18*2}[/itex]=1 (mod 1026)
(g[itex]^{18}[/itex])[itex]^{18*2}[/itex]=1 (mod 1026)
(g[itex]^{18}[/itex])[itex]^{18}[/itex])(g[itex]^{18}[/itex])[itex]^{18}[/itex])=1 (mod 1026)
So the element (g[itex]^{18}[/itex])[itex]^{18}[/itex]) is necessarily the identity or of order 2. A simple check shows that there are no integers h[itex]\in[/itex]G between 2 and 1025 such that h=(g[itex]^{18}[/itex])[itex]^{18}[/itex])=[itex]\sqrt{1026n+1}[/itex], n some positive integer.
Thus (g[itex]^{18}[/itex])[itex]^{18}[/itex])=1 (mod 1026).
(Is the above reasoning correct?)
And here begins my trouble. I wish somehow to show that the greatest order of any element in G is 18 and that any other orders are composed of prime factors of 18. I suppose that the fundamental theorem of finitely generated abelian groups is of limited use here, since there are som many possible combinations of prime factors.
I figure that the totient function will be of some aid, but I can't find a reason as for why there can't for instance be any elements in G of order 12 or 27. What makes 18 (or 9,6,3,2,1) so special?
Could someone please give me a tip?
Thanks!
##\phi(1026)=18^2## and not ##18^2 \cdot 2##.
Thank you morphism.
I did notice myself yesterday that phi(1026)=18^2. However, I could not deduce why there are no elements in G of order greater than 18.
The homework is already due and I will have it corrected and commented soon. But if someone still feels like coming up with suggestions you are very welcome.
I simply can't get why there are no elements for which g^18[itex]\neq[/itex]1. For instance, can't there be any elements of order 12 or 27?
Probably the easiest way to approach this is to note that we have the ring isomorphism $$ \mathbb Z / 1026 \mathbb Z \cong \mathbb Z/2 \mathbb Z \times \mathbb Z/ 3^3 \mathbb Z \times \mathbb Z/19 \mathbb Z $$ (this comes from the chinese remainder theorem) and hence the isomorphisms
$$ (\mathbb Z / 1026 \mathbb Z)^\times \cong (\mathbb Z/2 \mathbb Z)^\times \times (\mathbb Z/ 3^3 \mathbb Z)^\times \times (\mathbb Z/19 \mathbb Z)^\times \cong \mathbb Z/ (3^3 - 3^2) \mathbb Z \times \mathbb Z/(19-1) \mathbb Z \cong \mathbb Z/18 \mathbb Z \times \mathbb Z/18 \mathbb Z $$ of the unit groups.
  • · Replies 16 ·
