What are the properties of transverse waves?
The discussion revolves around the properties of transverse waves, focusing on concepts such as wavelength, period, energy transfer between particles, and the relationship between oscillation and wave formation. Participants explore both theoretical and conceptual aspects of wave behavior in a medium, particularly in the context of a string.
  • One participant questions whether the wavelength is the length of a complete wave and expresses confusion about the relationship between particle oscillation and wave formation.
  • Another participant asserts that the wavelength is the distance between two crests or troughs and suggests that thinking of waves as a "dominoes" effect complicates understanding.
  • A participant raises concerns about how particles can gain kinetic energy simultaneously without disrupting the wave nature.
  • Discussion includes the idea that while particles oscillate at different times, they complete their oscillations in the same period, leading to a complete wave formation.
  • Some participants introduce analogies to illustrate time periods and oscillation, such as counting to ten at different starting points but still taking the same duration to complete the count.
  • There is a mention of photons and their oscillation, which some participants feel deviates from the classical wave discussion.
  • One participant emphasizes the importance of understanding energy transfer in waves, suggesting a progression from simple systems like pendulums to more complex wave behaviors.
  • A question is raised about whether all waves considered in the discussion are isochronous, indicating a potential area of exploration regarding wave properties.
Participants express differing views on the nature of wave formation and the timing of particle oscillations. While some agree on the definitions of wavelength and period, others contest the implications of these definitions on how waves propagate through a medium. The discussion remains unresolved with multiple competing views present.
Participants express uncertainty about the implications of energy transfer and timing in wave mechanics. There are references to various models and analogies that may not fully align, indicating a need for clarity on definitions and concepts related to wave behavior.
Celluhh
Ok, so the wavelength is the length between two crests. Is it also the length of a complete wave? (sorry if I sound really stupid) The period is the time taken for one particle that makes up the wave to complete its oscillation, and it is also the time taken to make one complete wave. But I don't understand why this is so. I may be complicating matters, but I can't seem to stop thinking about it until I get it right. There is energy being transferred from particle to particle in a wave. When the first particle gets its kinetic energy from the source of vibration, it starts to move up and down, and transfers its energy to anther particle or it to start moving up and down, and this continues for all consecutive particles which make up the eventual wave. Since there is time lost while energy is being transferred from one particle to
Another, doesn't this
Mean that the first particle will complete it's oscillation before the other particles. How then, will they all manage to make one complete wave in a particular period?
Here is the question that got me thinking:(it's not supposed to be tough, but again , I like to think a lot. )
The speed of a transverse wave on a string is 450m/s. while the wavelength is 0.18m. The amplitude of the wave is 2.0mm. How much time is required for a particle for the string to move through a total distance of 1.0 km? I can deduce from this that a particle on the string covers 8.0mm in one oscillation, but I don't see how how the wavelength applies when we are talking about the particles. If anyone can enlighten me on these questions whih have been bugging me since a few days ago, pls help . Thank you !
you are over complicating matters. the wave length is the distance between two crests or troughs in the wave, you are correct. but to think of a wave as some kind of 'dominoes' effect, is confusing. as long as the wave length remains constant, so will your time period. and if you want to consider all the particles moving in a wave, then yes, each particle is in a slightly different position within the wave, but this does not mean that they have a slower time period.
But how can all the particles in a wave gain kinetic energy at the same time, if that is so it won't be a wave anymore... Ok maybe I don't make sense.
consider a single photon traveling in a straight line. it has energy, and it is oscillating through a wave form.
the particles in the string don't get given the energy all at the same instant, which is why parts of the string are in different parts of the wave. a wave travels through a medium, like you said, by passing on it's energy.
when i say 'time period' i am referring to the time it takes for the particle to move through 2pi radians, not the time at which that particle was given energy.
if you drop two identical balls onto a surface, at different times, they won't hit the ground at the same time, nor will they reach their highest point at the same time, but the time it takes for them both to do this, will be the same.
Exactly! Because the time period is the same, the dirt particle will finish its oscillation faster than others, won't it ??
yes. so the wave moves on through the medium.
Yeah so how can one complete wave be made by the respective particles in the same time period??
because if i start counting to ten at t=0 and you start counting to ten at t=1, i will reach ten before you do, but it will still take us both ten seconds to complete the count.
this would be easier if i could draw some diagrams for you.
If we are supposed to add up to twenty, at the end of ten seconds, we would only be nineteen!
you misunderstand. if i am saying the time period of a certain event is ten seconds, it takes ten seconds for that event to complete.
it makes no difference when another event starts, yours takes ten seconds too.
your event doesn't stop simply because i finish before you.
i think it would be useful for you to find some short and clearly defined definitions of wavelength, frequency, and time period.
The period is the time taken to complete one wave. But at the end of the period, due to all the particles needing the same time to complete one oscillation, which is something like both of us needing 10s to complete the race, there is no way a complete wave would be formed once the period is up, and some particles re still halfway into their oscillation.
Can I ask u something to see if we are actually visualising the same thing?? To you, when a particle on the wave comPletes one oscillation, does that mean a complete wave cycle is formed?
yes, the particle starts at 0 radians, it then moves to pi/2 radians and so on, completing a whole 2pi radian rotation.
2pi radians = 360 degrees.
there are 2 pi radians in one oscillation on a sin curve
If we are dealing with a wave on a string is REALLY can't be helpful to introduce Photons into the situation. Who ever said that photons are "oscillating through a wave form", anyway? Can we please stick to the classical wave stuff until we get it properly sorted?
@Celluhh
Remember that a wave (to be a wave) varies in distance and time. Each particle on your string (or whatever) goes through a complete cycle of motion in the same time as every other particle - there is just a slight delay for each successive particle on the wave path.
A freeze frame picture of the wave as it travels will show you the spatial form / wavelength and watching just one point to see how the displacement varies in time will tell you the frequency.
If you draw a wavy line on a long piece of paper and move it in front of you, the line goes up and down at the frequency of the wave and the space between identical parts of the wave is the wavelength. The speed that the wave is traveling will be the frequency times the wavelength - (how many waves pass in a second times their length).
i was trying to create an example where there is one object oscillating without considering what happens to other particles.
in hindsight - that was a bad choice
@ intz I knew what you were trying to get at so it's ok. @sophiecentaur if I understand you correctly you are saying we can consider the freeze frame picture of the wave to be as if the complete wave is formed in the given period although there is a time lag between the movement of particles?
To be perfectly frank, I know how to use the terms to find myself the answer. But what I want to know is not how to find the answer based on formulas, but truly understanding
How the answer is derived. which is why I think too much most of the time . And why I can't understand the simple school question I posted in my first post.
It is perhaps useful to first understand how energy is transferred between kinetic and potential energy in the classic pendulum (force = F = mg), then with a mass on a coil spring with a F= -kx restoration force, then finally with the tension on a string creating a restoration force and a traveling wave.
is it safe to assume that all the waves we are considering are isochronous?
to me it looks like you're moving into SHM, but is this a decent explanation of how a wave behaves?
Yes. Particularly because there is no particular evidence that a 'photon' actually oscillates.
At one instant of time, all the particles are in different places - along the profile of the wave (Think of a photo of water waves). Each one is oscillating a bit earlier in phase than its downstream neighbour and a bit later than its upstream neighbour.
The definitions of wavelength and frequency support this idea.
Not all waves are based on SHM movement of the 'particles' but it is easier to start with such waves. Using a different waveform just makes things more complex.
maybe oscillates was again not a great choice in words.
i am no expert, and still a student, so i am very much still learning.
what is a better word for describing a photons motion then? (sorry for taking this offtopic slightly)
No. They are all the same frequency only.
Yes. Using the string example of the OP, each segment of the string has mass, and is undergoing simple harmonic motion in the transverse dimension, with the string tension providing the restoring force. No segment "knows" that the SHM is actually part of a traveling wave.
So why then is there a traveling wave on the string? Because the transverse restoring forces on the two ends of the segment are different (even though the tension is the same).
String segments can be arbitrarily small.
A Photon is not something that can be described in simple terms like a particle that wiggles from side to side on its way from A to B. It is massless - so it's not like the other 'particles' we're used to dealing with and it travels at c. If it were to be wiggling from side to side it would, actually, need to be going FASTER than c in order to go the same distance because it would be traveling further. It's a difficult one.
But, as you say, this thread isn't the place to discuss it and I think you'll see that it doesn't really help in getting to grips with classical waves on strings or in air or wherever.
Yes I share the same sentiments as you but I don't get how the definitions if wavelength and frequency support this idea. Also, I still do not understand how the period is the time taken to create one complete wave when the above stated is actually true.
Perhaps, if you tried to show it wasn't true, then you'd find that you can't. It all makes such good sense to me. ;-)
Do that thing with a wavy line on a long piece of paper, moving to the right. It may help; the picture is the wave in space and the bobbing up and down is the time variation. The two variables are separate and I think you are connecting the two in your mind.
if you are studying physics in, then i really do recommend that you speak to a teacher/lecturer about this.
it is not easy to explain clearly in words, without the use of diagrams.
Yup I plan to ask my teacher when I go for tuition! Anyways thanks guys for helping
Bob s, can I trouble you to explain shm in a simpler manner? I have
Not touched on that topic yet but if it could help me
In understanding , I'm interested.
It might be useful to first look at what produces the wave velocity v in a string or other long connected line of masses. When the wave equation for a vibrating or plucked string is derived, the wave velocity for a string of mass ρ kilograms per meter and longitudinal tension T Newtons is
[tex]v=\left[ \frac{T}{\rho} \right]^{1/2} \text{ meters per second }[/tex] The string mass per unit length ρ is equivalent to a mass m on a simple spring, and the tension T Newtons is equivalent to the restoring force F on a compressed or extended spring. The net transverse restoring force on a unit length of string is due to the fact that at every moment in time, the transverse restoring force at point x is approximately Fx = T tan(θx) because the string has a slope tan(θx) with respect to the unplucked string, so for a segment of string δx, the net restoring force is
[tex]F=T\left[ \tan\theta_{x+\delta x}-\tan\theta_{x} \right][/tex]
This is because the string is flexible, and there is curvature between x and x + δx. Thus each segment of string undergoes SHM (simple harmonic motion).
In a simple mass on a spring, the restoring force is F = -k(y-yo) = m d2y/dt2, leading to an angular oscillation frequency ω = (k/m)1/2 radians per second.
