Centripetal Force - maxium downforce for no skidding
The discussion revolves around the concept of centripetal force in the context of a racing car navigating a turn. The original poster presents a scenario involving a car's mass, speed, and the radius of the turn, seeking assistance with understanding the forces at play, particularly the downward force required to prevent skidding.
  • Participants explore the role of friction in providing centripetal force, questioning its direction relative to the car's motion. There are attempts to clarify the relationship between the forces acting on the car and the concept of inertia.
The discussion is active, with participants offering insights into the nature of friction and its role in circular motion. Some express confusion regarding the comparison of different forces and the implications of inertia on the car's movement. No consensus has been reached, but various interpretations of the forces involved are being explored.
Participants are grappling with the definitions and assumptions surrounding friction and centripetal force, as well as the implications of the car's inertia during a turn. There is an acknowledgment of the complexity of visualizing these forces in a practical scenario.
jsmith613
Downward force is used to keep a car in contact with the track. The motion through the air produces a force ppd to direction of travel pushing the car ONTO the track. A racing car of mass 720 kg takes an unbanked corner of radius 550 m at a speed of 50 m/s
The max frictional force is 0.4*(reaction from track).
Calculate the downward force necessary to prevent the car from skidding outward.
Could someone please assist me in the drawing of a free body diagram
So at the moment I know that the:
R = mg + D (as the car does not rise above the track)
thus the free body diagram would have R up and (mg + D) down
assuming the track curves like this: ( (
which direction will the frictional force act in, this is the final puzzle to the problem :S
I would have said it acts towards the OUTER part of the track but the car needs to move in a circle and the only force providing centripetal acceleration appears to be friction
any help is greatly appreciated
http://hyperphysics.phy-astr.gsu.edu/hbase/cf.html
so by this it is towards the centre
BUT HOW?? why is frictional force in the direction(kinda anyway)??
so in this case it is the frictional force of the road on the car but why does it act towards the centre of circle not straight ahead?
here seems to be a diagram (attachment)
how does the force of friction on the tyres cause centripetal force, surely it would act in the opposite direction
Friction is the only force that allows the car to turn a corner. Think about this: If you're sitting in the middle of the back seat of the car as it goes around a turn, and you must hold yourself steady in the seat with friction. Which direction would you feel the friction against the seat pulling you? This is the same direction that the friction against the road pulls the cars tires.
Imagine a circle
what ever point I am at my tyres will be at an angle (e.g: 30 degrees) BUT how does this provide the frictional force that provides the centripetal force 90 degrees to the direction of travel
jsmith613 said:
Imagine a circle
Friction acts in the direction opposite from where the car would accelerate otherwise. The friction is simply resisting your car's inertia wanting to go off track. Think about the situation I posed in my last post. When you're inside the car and the car turns, the inertia of your body wants to resist the car's turn and you feel accelerated directly away from the axis of your turn, but the friction of the seat pushes you towards the axis of the turn, keeping you on the seat.
Think about the direction that you feel the seat pulling your pants. The friction from the seat is pulling on your pants in the direction of the axis of rotation.
Assuming the car isn't skidding, it will go in the direction that the wheels are pointed. If the wheels are constantly turned so that the car goes in a circle, then the car would "feel" an acceleration away from the center of the circle, and so the friction will counter-act that acceleration, pointing in the opposite direction, which is toward the center.
there is no such thing as a centrifugal force! therefore this cannot be the cause of friction!
I never said that a centrifugal force would be the cause of friction. Not once did I mention a centrifugal force. I'm not sure where you got the idea that this would be the case.
you said "then the car would "feel" an acceleration away from the center of the circle" this is centrifugal
This feeling is the car's inertia. When the car accelerates towards the center of a circle, its inertia is going to resist this acceleration in the opposite direction. You can feel the same effect from your inertia every time you're in a car that makes a turn. I'm sure you can imagine this effect if you imagine you were in a car that's driving in circles. You'd feel like you were being pushed against the car door away from the center of the circle. This is not centrifugal force, this is your inertia resisting the car's turn.
This resistance to the turn due to the car's inertia is what causes the friction to face the center of the circle. This friction is opposing the car's resistance to turning.
would we have a situation like this:
Where / is the fricitonal force and ------ is the horizontal compoenent and | the vertical componenet (all on a flat surface so | is straight ahead and ---- is to the side
so the ---- is actually F cos(θ)
this is very confusing :confused:
yes, if the car is turning left, the passenger is in a rotating frame, and feels a centrifugal force to the right, so the friction from the car is to the left, the same direction as the friction on the car that pulls the car in a circle
but i don't see how it helps to compare two different frictions, one from the car, one on the car, in two different frames of reference :redface:
the direction of friction from the road is obtained by F = ma
jsmith613 said:
Imagine a circle
the direction of the tyres is irrelevant …
suppose the car had a jet engine, and blocks instead of tyres …
point the jet at 30˚, and the car will slide in a circle …
what provides the friction for it to do that? :smile:
Man the thing is-
It is the car that pushes against the friction and goes towards the center.
Like you push an object and go away with the reaction force.
And as long as tilting is concerned it automatically adjust itself such that it cause the force of gravity to aid(that is if u r tilted at an angle theta from the horizontal u will have a forve of mg sin theta inwards and so on.
but I don't understand this
If the car is moving forward, friction is backward
if the car turns the wheels, the front wheels still move forward so friction should have a component providing centrpetal force not be the entire centrpietal force?
hi jsmith613! :smile:
no, that's only for kinetic friction
there's no kinetic friction between the tyres and the road (if there was, the tyres would slide, and leave tyre marks on the road :wink:)​
you need to apply the rule for static friction, which is that the direction of friction is opposite to the relative motion that would occur if the road suddenly turned to ice :wink:
tiny-tim said:
hi jsmith613! :smile:no, that's only for kinetic friction
http://en.wikipedia.org/wiki/Friction#Static_friction
static friction is for: two or more solid objects that are not moving relative to each other
here the road and the car are solid and are moving relative to each other
so surely it is kinetic?
ah, but two paragraphs later, it says :wink:
An example of static friction is the force that prevents a car wheel from slipping as it rolls on the ground. Even though the wheel is in motion, the patch of the tire in contact with the ground is stationary relative to the ground, so it is static rather than kinetic friction.​
the question still is why does this act at right angles to direction of motion?
As long as the wheels aren't skidding, the friction between the car's wheels and the road is static. The part of the wheel touching the ground doesn't slide against the ground; once it's pressed against the ground, it sticks to that spot on the ground (with static friction) until it's lifted back off.
Static friction always opposes an acceleration. The car's inertia resists the circular path, causing the car to want to travel in a straight line, and not in a circle. Since the car's inertia would cause the car to go in a path that would cause the tires to skid, the rules for the direction of the static friction of the tires say that the direction must oppose the inertia. If you draw a force vector that would oppose the car's inertia and cause it to stay directly on the circle, this vector points directly at the center of the circle. Because of the rules for static friction (which say the tire's friction must oppose the car's inertia), this vector arrow is the direction that the tire's friction points.
