| New Reply |
Thought experiment with two point sources of light |
Share Thread | Thread Tools |
| Mar30-12, 03:13 PM | #1 |
You are in a dark room with no other sources of light
The walls are painted black, so no light is scattered from walls You have two point sources of light of equal power + same height about ground They are 10 feet apart You stand a thick rod vertically in middle of two, and 4 feet in front of the point sources What kind of shadow will be cast? 1) one shadow from one lamp? 2) two shadows from both lamps? 3) only intersection shadow from both lamps? 4) other? Explain your answer!
| Mar30-12, 05:04 PM | #2 |
depending on how bright the lights are, you'd see two shadows. If they were reaaaally bright, there'd be no shadows, but if they weren't so bright you'd see two shadows. Each shadow would be not as dim as would be if the other light weren't on.
I'm basing this on personal experience of remembering shadows on auditorium stages with multiple lights. Usually the object would cast as many shadows as there were lights above it, but the lights that were further away (or dimmer) would cast shadows that weren't as "strong" as the shadows cast by the lights that were closer (or brighter). |
| Mar30-12, 05:39 PM | #3 |
Almost....
![]() With answer comes another question, but there are more than 2 shadows. |
| Mar30-12, 06:13 PM | #4 |
No. Whether Paul Muadid intended it or not, it's a trick question.
No shadows are cast. "...no light is scattered from walls." :) |
| Mar30-12, 06:20 PM | #5 |
No light is scattered from walls, but the two point sources of light are generating light.
(in other words, the walls do not enter equation) |
| Mar30-12, 06:34 PM | #6 |
You get 4 shadows. Each source casts a shadow of the rod and the other light source. |
| Mar30-12, 06:38 PM | #7 |
| Mar30-12, 06:41 PM | #8 |
There is a floor, the shadow (whatever shadow that would be) would be cast on the floor.
| Mar30-12, 08:42 PM | #9 |
Recognitions:
Should we ask about the ceiling?
| Mar30-12, 09:19 PM | #10 |
There's a ceiling, it too is black and non-reflective.
Floor is white and can receive cast shadows. |
| Mar30-12, 11:55 PM | #11 |
Perhaps the OP simply wishes to say "the walls reflect little enough light that any secondary reflections can be ignored".
| Mar31-12, 03:05 PM | #12 |
A "shadow" counts as a separate shadow if it is from a different source OR if its gradient is different.
We're only interested in shadows cast onto floor. There are three. ![]() I'm still not sure why shadow 2 and 3 are not completely canceled out. Shadow #2 is closer to left light source, so the left light source should completely cancel out the #2 shadow. The same for #3. Does it depend on how bright the light is? Shadow #1 (the intersection of both shadows) is darker than #2 and #3 |
| Mar31-12, 03:52 PM | #13 |
One light source, one shadow. Two light sources, two shadows. The darker area is simply the intersection of the two shadows. It is not a third shadow. BTW, the lights themselves will cast shadows of each other. Do you choose to ignore this? |
| Mar31-12, 05:17 PM | #14 |
The words Umbra and Penumbra come to mind.
The problem isn't presented in an unambiguous way so it's hard to be sure what they're after. I don't know how any shadow can "cancel out" another. The sum of the illumination 'outside' any shadow must be greater than the illumination within a shadow. |
| New Reply |
| Thread Tools | |
Similar Threads for: Thought experiment with two point sources of light
| Thought Experiment on the speed of light | Special & General Relativity | 5 | ||
| Thought experiment on the nature of light | Special & General Relativity | 2 | ||
| Speed of Light Thought Experiment | General Physics | 5 | ||
| Max distance of resolution from 2 point sources of light | Introductory Physics Homework | 1 | ||
| Light point sources | General Physics | 1 | ||
