What are the local maxima and minima of F(x)=(x^2)/(x+1)?
The discussion revolves around identifying local maxima and minima for the function F(x)=(x^2)/(x+1). Participants are tasked with finding critical points and determining the nature of these points.
  • Participants discuss the critical points derived from the first derivative and express differing views on the classification of these points as maxima or minima. There is a suggestion to apply second-order conditions to clarify the nature of the critical points.
Some participants have provided guidance on applying second-order derivative tests to determine local maxima and minima. There is acknowledgment of differing interpretations regarding the classification of the critical points, but no consensus has been reached.
Participants note that the local maximum identified is less than the local minimum, which raises questions about the definitions and conditions for local extrema.
jorcrobe
F(x)=(x^2)/(x+1)
Find critical points
Find local maxima & minima
None
F'(x) = x(x+2)/(x+1)^2
crit points: -2,0,-1
f(-2) = -4
f(0) = 0
f(-1)=undef
My book is telling me that f(0) is the minima, and f(-2) is the maxima. I see it as the other way around. Which way is right? Explanations? Thank you!
jorcrobe said:
F(x)=(x^2)/(x+1)
None
f(-2) = -4
f(0) = 0
f(-1)=undef
My book is telling me that f(0) is the minimum, and f(-2) is the maximum. I see it as the other way around. Which way is right? Explanations? Thank you!
The book is correct.
I suppose you're having trouble because the local maximum is less than the local minimum.
Graph F(x) to see what's happening .
jorcrobe said:
F(x)=(x^2)/(x+1)
None
f(-2) = -4
f(0) = 0
f(-1)=undef
The book is correct. For *local* min/max (as you have here) there are second-order conditions that can be applied: if f'(x0) = 0 and f''(x0) < 0 then x0 is a strict local maximum; if f'(x0) = 0 and f''(x0) > 0, x0 is a strict local minimum. Try these tests on your function.
This does not say anything about *global* max or min, and it does not prevent a local max from being less than a local min, which is the case in this problem.
RGV
I'd like to thank you both for your guidance. I will be looking into this further.
