Rotation, torque, angular momentum?
The problem involves a uniform solid cylinder with a cloth tape wound around it, which is released from rest and unwinds as it descends. The context includes concepts of rotation, torque, and angular momentum, with specific questions about forces, acceleration, angular velocity, and motion direction.
  • Exploratory, Assumption checking
  • Participants express uncertainty about how to begin solving the problem, particularly regarding the identification of forces and the application of relevant equations.
The discussion reflects a lack of initial attempts from the original poster, with some participants suggesting a review of foundational concepts. There is no consensus on a direction for solving the problem, as participants are still exploring basic understanding.
There is an indication that the original poster has not made significant progress on the problem, and participants are emphasizing the need for an initial effort before further assistance can be provided.
kjn11994
A cloth tape is wound around the outside of a uniform solid cylinder (mass M, radius R) and fastened to the ceiling as shown in the diagram below. They cylinder is held with the tape vertical and then released from rest. as the cylinder descends, it unwinds from the tape without slipping. The moment of inertia of a uniform solid cylinder about its center is 1/2MR^2.
diagram: http://imgur.com/h0v07
A. draw and label a diagram of the cylinder showing all the forces acting on the cylinder after it is released. label each force clearly.
B. in terms of g, find the downward acceleration of the center of the cylinder as it unrolls from the tape
C. what is the angular velocity of the cylinder after it has descended 3 meters?
D. while descending, does the center of the cylinder move toward the left, toward the right, or straight down? Explain.
KEr=1/2MR^2
i have no clue how to solve this
You need to show us you made some effort before you can get help here. Did you at least do part A?
i honestly have no idea where to start...
Then I would suggest you go back and read your text, particularly the examples. Identifying the forces is pretty basic. You should have covered it in class weeks ago. You can open a new thread after you've made some sort of attempt at solving the problem on your own.
  • · Replies 35 ·
13K
  • · Replies 17 ·
