Ok then since I am wrong then formula for torque is wrong
  • Thread starter Thread starter sweetpete28
    Formula Torque
The discussion revolves around calculating the magnitude of force applied to a uniform disk, which is mounted on a fixed frictionless axis. The problem involves concepts of torque, angular velocity, and rotational dynamics.
  • Mixed
  • Participants explore the relationship between torque, force, and angular acceleration. There is a focus on the calculation of angular velocity and the implications of assuming constant angular velocity. Questions arise regarding the correct application of formulas and the interpretation of results.
Some participants have provided guidance on recalculating average angular velocity and time, leading to revised torque calculations. There is ongoing exploration of the implications of these calculations on the force value, with no explicit consensus reached on the final answer.
Participants are discussing the implications of their calculations and questioning assumptions about angular velocity. There is a recognition that the initial approach may have been flawed, prompting a reevaluation of the problem.
sweetpete28
Force F is applied to the rim of a uniform disk (M=3.13kg, R=.193m). The disk is mounted on a fixed frictionless axis through its center, and the force is applied at an angle β=45.8° to the radius. The disk starts at rest, and reaches frequency f = 61.1 revolutions per second after rotating through an angle θ = 609 radians.
What is the magnitude of force F?
Torque = FRsinβ
Torque = I∂
∂ = ωf - ωi / t
ωf = 2∏f = 383.9026 rad/s
ωf = θ/t; 609 rad / 383.9026 rad/s = 1.586, so t = 1.586 s
∂ = 383.9026 / 1.586 = 242.005 rad/s^2
Torque = (1/2)(MR^2)(∂)
Torque = (1/2)(3.13)(.193)^2(242.005) = 14.1076
14.1076 = F(.193)(sin 45.8)
F = 102 N
But 102 N is wrong so I guess Torque really does not = FRsinβ
Can anyone help here...cause I have no clue why or how this could be wrong...
Good. That's the final angular velocity.
Careful. Do not assume that the angular velocity is constant. Redo this. (What's the average angular velocity?)
So [itex]\omega = 2\pi[/itex]?
I think he meant ωf = 2∏f.
Thanks Doc Al!
You're right!
ωavg = 0 + 383.9026 / 2 = 191.9513 rad/s so t= 609 rad / 191.9513 rad/s = 3.17267 s and ∂ = 383.9026 / 3.17267 = 121.002 rad/s^2 so...
Torque = (1/2)(3.13)(.193)^2(121.002) = 7.0538
and F = 7.0538 / (.193)(sin 45.8) = 51.0N...right?
Looks good!
  • · Replies 27 ·
20K
