What is the period of oscillation of the mass on the spring?
The discussion revolves around the oscillation period of a mass attached to a vertical spring, specifically addressing the calculations involved in determining the period and amplitude of oscillation based on given parameters.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between mass, spring constant, and oscillation period, with some questioning the relevance of angular velocity in this context. Others suggest focusing on energy equations to analyze the system.
Some participants have provided guidance on using the correct formulas for the period of oscillation and have discussed the assumptions made regarding the mass. There is an acknowledgment of the need to express variables symbolically rather than numerically until the final step.
There is a noted ambiguity regarding the mass of the object, with one participant assuming a mass of 1 kg for calculations. The original problem does not specify the mass, leading to discussions about how to handle such assumptions in problem-solving.
ScienceGeek24
a)When a mass is attached to the end of a vertical spring, the spring is stretched down 3 cm. If the mass is pulled down a bit farther and then released, what is the period of oscillation of the mass on the spring? b) if the mass moves through its equilibrium position at 50 cm/s, what is the amplitude of the oscillation?
T= 2pi/v , w= srqt(g/L) , T=2pi/w
I tried using w= srqt(g/L) because the problem only gives you with the radius of the ball, so i just that equation to find the angular velocity and than use w to find the period with T=2pi/w but i don;t get the right answer. which is 0.348 seconds.
for part b i just don;t even know how to start.
I need help?
I need help?
Non sequitur. What ball? Why angular velocity when you're dealing with a linear spring?
What radius of what ball? This is just a mass on a spring.
You want to look at the kinetic and potential energy. Write down the equation for energy at the beginning, and write down the equation for energy at the equilibrium position.
Got it! yeah i really didn't have to use any angular velocities. The hard part was assuming that the mass is 1 kg. because it only mentions mass and they don;t mention anything else so i tried 1 kg just for curiosity.
I used T=2pi*sqrt(m/k) i knew that k=F/deltay so (1kg)(9.8)/0.03m=326.7 N/m than plug everything in T=2pi*sqrt(m/k) and i got 0.347seconds which was the right answer. Thank gneill!
than for the second part I used A=VmaxT/2pi and got the right amplitude too.
Instead of 1kg you could have used mass of m[/color] and expressed k in terms of m[/color].
You should always solve problems symbolically. Only plug in numbers as the very last step (that is, if there are any numbers). That is the only way to understand the physics.
