New Reply
What is the pressure at 80 m below the surface of the ocean.
Share Thread Thread Tools
Apr1-12, 11:00 PM   #1
a) A sailor uses a rope to lower an iron ball of radius 30 cm a to a depth of 80 m below the surface of the ocean. What is the pressure (in atm) at that depth? b) Find the tension in the rope in the previous problem. The density of iron is 7.86 *103 Kg/m3.
2. Relevant equations
For part a) p=P0+ρGd
1 atm= 1.013*105 Pa
ρsea water= 1.03*103 kg/m3
For part b) Ʃy= F buoyant-mg-T=0
F buoyant=ρVg
ρ= m/V
3. The attempt at a solution
In part a) p=(1.013*105 Pa)+(1.03*103 kg/m3)(9.8 m/s2)(80m)= 9.08*105 Pa
9.08*105 Pa / 1.013*105 Pa = 8.97 atm
However, the answer is 8.74 atm what did I do wrong??
In part b) I solved for T=F buoyant-mg
F buoyant= (7.86 *103 )(4π(0.3m)3/3)(9.8m/s2)= 8.70*103 N*m
For mg I used m=ρV = (7.86 *103 )(4π(0.3m)3/3)= 8.70*103 N*m
So T= 8.70*103 N*m - 8.70*103 N*m =0 ?????? The answer for part (b) is 7600 N Help????
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr1-12, 11:48 PM   #2
You used 1030 kg/m3 for the density of the seawater. Could they have wanted you to use the density of water with no salt (1000 kg/m3)? The density of seawater varies quite a bit, depending on how much salt is in that part of the ocean. If they didn't specify the density of the water other than saying that it's "the ocean," I would guess they want you to use the standard density for water.
Apr2-12, 12:18 AM   #3
You were right! THANKS MAN!! I could solve both of them! thanks again!
New Reply
Thread Tools
Similar Threads for: What is the pressure at 80 m below the surface of the ocean.
Thread Forum Replies
Ocean tides and earths surface. General Physics 2
3D surface of the land and ocean floor Earth 1
Surface Waves of an Oil Ocean General Discussion 13
Pressure in the Ocean Introductory Physics Homework 2
Absolute pressure at an ocean depth Introductory Physics Homework 1
