How Do You Find the PDF of Z and Calculate Mean and Variance Using MGF?
  • Context: Graduate
  • Thread starter Thread starter silkdigital
    Joint Pdf
The discussion revolves around finding the probability density function (pdf) of a random variable Z defined as the sum of two random variables X and Y, given their joint pdf. Additionally, participants explore how to calculate the mean and variance of a random variable X using its moment generating function (mgf).
  • Homework-related
  • One participant presents a joint pdf for random variables X and Y and asks how to find the pdf of Z = X + Y.
  • Another participant mentions that the moments can be derived from the mgf by taking derivatives and evaluating at t = 0, noting the relationship between variance and moments.
  • A later reply suggests using a transformation approach to find the pdf of Z, proposing to set u = x + y and apply the transformation theorem.
Participants do not appear to reach a consensus on the method for finding the pdf of Z, as multiple approaches are suggested. The second question regarding the mean and variance of X seems to have been resolved by one participant, but the first question remains open for discussion.
Participants express uncertainty about the integration techniques required for the first question and the application of the transformation theorem. There is also a lack of clarity on the limits of integration when applying the transformation.
This discussion may be useful for students or individuals studying probability theory, particularly those interested in joint distributions, moment generating functions, and transformations of random variables.
silkdigital
Hi guys,
I'm really stuck on the following questions, not sure as to how to approach it:
Let X and Y be random variables for which the joint pdf is as follows:
f(x,y) = 2(x+y) for 0 <= x <= y <= 1
and 0 otherwise.
Find the pdf of Z = X + Y
And also:
Suppose that X is a random variable for which the mgf is as follows:
/u(t) = e^(t^2 + 3t) for minus infinity < t < infinity
Find the mean and variance for X.
I know that the answers are 3 and 2 respectively, but was unsure how they got to the answer, do I need to integrate by parts?
Any help would be appreciated! Thanks guys :)
silkdigital said:
Hi guys,
and 0 otherwise.
And also:
I'll address the second question only. The moments are obtained from the moment generating function by simply taking derivatives and setting t = 0. As you must be aware, the variance is the second moment minus square of first moment.
Figured out second question now, pretty straightforward in hindsight. Any help on the first one? ;)
Have you tried a transformation? Let u = x + y. Now use that transformation to get a integral in terms of u, take into account limits and then use transformation theorem to relate g(u) = 2(x+y) = 2u to another PDF f(u) which represents the distribution of Z.
  • · Replies 43 ·
