MATLAB Matrix dimensional error in numerical integration
The forum discussion addresses a MATLAB error encountered during numerical integration using the trapezium method. The error message "Error using / Matrix dimensions must agree" arises from MATLAB's matrix operation assumptions. To resolve this, users must employ element-wise operations by prefixing arithmetic operators with a dot, such as using ".*" for multiplication and ".^" for exponentiation. This adjustment allows for proper component-wise calculations in MATLAB.
  • Understanding of MATLAB syntax and operations
  • Familiarity with numerical integration methods, specifically the trapezium method
  • Knowledge of matrix operations in MATLAB
  • Basic programming skills to manipulate vectors and matrices
  • Learn about MATLAB element-wise operations, including ".*", "./", and ".^"
  • Explore MATLAB's numerical integration functions beyond the trapezium method
  • Investigate common MATLAB error messages and their resolutions
  • Practice creating and manipulating vectors and matrices in MATLAB
MATLAB users, particularly those involved in numerical analysis, data scientists, and engineers looking to enhance their understanding of matrix operations and numerical integration techniques.
sarrfriend
Hi,
I tried to numerically integrate an equation in MATLAB using the trapezium method. Here is the code that I wrote:
ao = 1;
X = 0:ao/10:ao;
Y = 1/sqrt((power(Ho,2)*((O_m*power(X,-1))+(O_r*power(X,-2))+(O_l*power(X,2))))-(k*power(c,2)));
age = trapz(X,Y);
where the values for O_m, O_r, O_l and k were obtained using input(). When I executed the above code, I get "Error using / Matrix dimensions must agree."
Can you tell me what the problem is?
Sarrvesh
sarrfriend said:
Hi,
ao = 1;
X = 0:ao/10:ao;
age = trapz(X,Y);
Sarrvesh
Hey sarrfriend.
MATLABs main data structure is a matrix and it treats pretty much everything in that way. This means that if you do say a * b, a + b and so on, then it assumes that this is going to be a matrix operation and it also assumes that the operations do things in terms of matrix assumptions (AxB a is axb, B is bxc and so on). This is why you get the error.
What you need to do if you want to do a component by component arithmetic operation is put a "." before the operation. For example let's say we have a vector A [0,1,2,3,4,5] and another vector B [0,2,4,6,8,10]. Then if we write C = A .* B we get [0,2,8,18,32,50]. If you want to do exponentiation just use .^ operator instead of power which will do a component wise exponentiation.
If you want to know more create a few row vectors of the same size and try .* ./ and .^ and see what you get in the output.
Hi Chiro,
Thanks the info. It worked.
Sarrfriend
