Forces, I want to get the magnitude of the acceleration for the following problem ple
The discussion centers on calculating the acceleration and tension in a system of two 2kg masses connected by a massless string, where one mass moves vertically downward and the other moves horizontally on a frictionless surface. The horizontal mass is subjected to a 10 N force at a 60-degree angle. The user correctly applied Newton's second law, resulting in equations for both masses: T - mg = ma for the vertical mass and 10cos(60) - T = ma for the horizontal mass. The user questioned the sign of the acceleration but received confirmation that their solution was correct.
  • Understanding of Newton's laws of motion
  • Basic knowledge of vector components and trigonometry
  • Familiarity with tension in strings and forces in equilibrium
  • Ability to solve linear equations
  • Study the application of Newton's second law in multi-body systems
  • Learn about vector decomposition in physics
  • Explore tension forces in different configurations
  • Investigate the effects of angles on force calculations
Students in physics, educators teaching mechanics, and anyone interested in solving problems involving forces and accelerations in connected systems.
madinsane
Question says.
Two objects of mass 2kg each are attached to each other by a massless string. One moves vertically and the other is moving on a frictionless surface horizontally and is being pulled the opposite direction by a force of 10 N at 60 degrees to the horizontal get the acceleration of each object and then get tension
My solution
Total fy for vertical object is
T-mg=ma
For the second I got forces in x direction as 10cos60 -T=ma
I then solved for a and got a negative answer then I substituted that value to get T. But should I have written a as positive? Is my solution correct
you give {a} against the point.
(((One moves vertically))))moves down
your solution is correct
(((one moves vertically))))moves down
thanks!
  • · Replies 30 ·
12K
  • · Replies 29 ·
