Determine Value of Trig Functions
The discussion revolves around determining the values of trigonometric functions at the point (-3, -4) in relation to the angle theta in standard position. Participants explore the quadrant in which this point lies and the implications for calculating sine, cosine, and tangent values.
  • Participants question how to identify the quadrant based on the coordinates, with some asserting that the point is in the third quadrant. There is discussion about using the definitions of trigonometric functions based on the coordinates and the hypotenuse.
The conversation is active, with participants providing insights and clarifications about the quadrant determination and the calculation of trigonometric values. There is a mix of agreement on the quadrant location and the method for calculating the functions, but no explicit consensus on the final values.
Participants reference the importance of understanding the signs of trigonometric functions in different quadrants and the relevance of a diagram for visualizing these concepts. There is an emphasis on memorizing the characteristics of each quadrant.
aisha
My question is to determine the values of the primary and secondary tri functions at (-3,-4) on the terminal arm of an angle theta in standard position
Im just wondering how do u know which quadrant this point is in? I have assumed it is in quadrant 1. Then that means x=-3, y=-4, and r=5?
When determining values for trig functions for example let's say
[tex]\sin= \frac {opposite} {hypotenuse} = \frac {-4} {5}[/tex] is this the value they want me to determine or do I have to put it in decimals?
IIRC,the point of coordinates x=-3,y=-4 is in the 3-rd quadrant.Its distance to the center is 5.
Can u take it from here??
Daniel.
yes just tell me how u know its in the third quadrant? and all I have to do is put opposite/hyp and then adj/hyp etc to determine the values for all the tri functions right?
This image should help you.
http://www.mmsonline.com/mag_images/cnc9801e.gif
BECAUSE THE COORDINATES OF THE POINT ARE BOTH NEGATIVE:If "x" is negative,then it's either in the II-nd or the III-rd quadrant.If "y" is negative it's either in the III-rd or the IV-th quadrant.
Figure out what happens if both are negative at the same time...
For the second part,"YES".
Daniel.
I would memorize that drawing Recon linked to. If you look at it as a graph (which it is), it's pretty self-explanatory why cosines are positive in Q1 and Q4 and why sines are positive in Q1 and Q2. But, knowing that drawing one way or the other is pretty much essential for most of the trig problems you're doing.
yes recon's diagram is good I was thinking something more complicated lol i know that going to the left will become negative in the x-axis and down is negative in the y-axis thanks for explainging and making it more clear.
  • · Replies 29 ·
