How Much Will the Beam Deflect?
The discussion revolves around the deflection of a steel beam under a specific load. The beam is 50 feet long and supports a total weight of 6000 pounds at its center, with additional parameters provided such as the modulus of elasticity and moment of inertia.
  • Exploratory, Assumption checking
  • Participants are questioning the nature of the load, specifically whether it is concentrated at a single point or distributed over a distance. There is also a request for the original poster to clarify their attempts or understanding of the problem.
The discussion is ongoing, with participants seeking clarification on the load distribution and encouraging the original poster to engage more with the problem. There is no clear consensus yet, as the original poster has expressed uncertainty about the terminology used in the problem.
The original poster has indicated that they are not approaching this as a homework question but rather as a trivia question, which may affect the nature of the responses and guidance provided.
chelzey75
can anyone answer this for me? There was a steel beam 50 feet long. The entire Skeith construction crew (total weight: 6000 pounds) was standing at the center of the beam. Assume the modulus of elasticity is 29,000,000 pounds per square inch, the moment of inertia is 850 inches^4, the beam has simple pin connections at either end, and all loads other than the weight of the crew are disregarded.
How much will the beam deflect? Please round to the nearest tenth of an inch.
First off, please don't double (or triple) post.
Second, homework questions belong in the 'homework help' section of the forums. I'm moving this thread there now.
Third, to get help with homework questions, we ask that you post what you've tried, even if it's only as much as looking up relevant equations.
Give it a shot.
Welcome to the forums!
first sorry about the multiple postings.. 2nd its not homework its a trivia question and i would love to tell you i have tried solving it on my own however i don't know what some of those words even mean...i was just trying to get an answer to a trivia question. No big deal if you can't help :)
Is the load considered to be located at a single point, or is the crew spread out over a given distance?
-Mike
