| New Reply |
Magnitude and direction of magnetic field |
Share Thread | Thread Tools |
| Apr5-12, 05:59 PM | #1 |
http://desmond.imageshack.us/Himg37/...jpg&res=medium 2. Relevant equations B = [itex]\frac{μI}{2πr}[/itex] 3. The attempt at a solution B = [itex]\frac{μ(12)}{2π(0.4m)}[/itex] - [itex]\frac{μ(12)}{2π(0.1)}[/itex] B = -1.8 x 10-5 I'm not sure if I am doing this correctly, am I supposed to add up the magnetic fields produced by both wires like this? Thanks for helping! |
| Apr5-12, 06:12 PM | #2 |
Recognitions:
Yes, add up the magnetic fields produced by each wire at location A. The directions of the individual fields is determined by the right-hand-rule for currents and fields.
If you apply the right-hand-rule, what's the direction of the field produced by I1 at A? How about I2? |
| Apr5-12, 06:13 PM | #3 |
Mentor
| Apr5-12, 06:16 PM | #4 |
The direction of the magnetic field at point A by I1 is downward. And the direction of the magnetic field by I2 is upward.
My thoughts: So,..since I chose the downward direction to be positive, and the answer I got was negative, that means the direction of the resultant magnetic field is upward? Thanks for the help guys! |
| Apr5-12, 06:19 PM | #5 |
Mentor
Why did you choose downward as positive? That's fine if you specify that in your answer, but it would be more traditional to choose (x,y,z) on the paper as (pointing East on the paper, pointing North on the paper, pointing out of the paper up at you). |
| Apr5-12, 06:37 PM | #6 |
| Apr5-12, 06:42 PM | #7 |
Mentor
| New Reply |
| Tags |
| magnetic field, magnetism, magnitude |
| Thread Tools | |
Similar Threads for: Magnitude and direction of magnetic field
| magnitude and direction of uniform magnetic field | Introductory Physics Homework | 1 | ||
| Magnetic field problem: What are the magnitude and direction of the electric field.. | Introductory Physics Homework | 1 | ||
| Magnitude and Direction of Magnetic Field | Introductory Physics Homework | 3 | ||
| Magnitude & Direction of Magnetic Field | Introductory Physics Homework | 0 | ||
