When is the magnetic flux on a section of a closed surface equal to zero?
The discussion revolves around the conditions under which the magnetic flux through a section of a closed surface is equal to zero. The participants explore different scenarios based on the orientation of the magnetic field relative to the area vector of the surface.
  • Conceptual clarification, Mathematical reasoning
  • Participants consider various options regarding the relationship between the magnetic field and the area vector, specifically discussing when the magnetic flux could be zero. There is an exploration of the implications of perpendicularity and the use of relevant laws.
The discussion has progressed with some participants confirming their understanding of the concept of magnetic flux and its calculation. There is a recognition of the mathematical relationship involved, although not all participants agree on the necessity of applying specific laws.
Some participants express uncertainty about the definitions and implications of the laws of electromagnetism, particularly Lenz's and Faraday's laws, in relation to the problem at hand.
McAfee
A. When the magnetic field is in the direction opposite that of the section’s area vector.
B. When the magnetic field is in the direction of the section’s area vector.
C. When the magnetic field is perpendicular to the section’s area vector.
I have ruled out the answer A because it doesn't make sense.
I think it is C because when perpendicular it might cancel out it out. I'm not sure whether you have to use Lenz's or Faraday's Law?
In what way?
You're simply being asked to find the flux. You don't need to use either law.
Oh. ok so flux = B.A.cos x , where x is the angle between magnetic field and area vector.
since x= 90 degree cos x = 0 and hence flux = 0.
The answer is C. I'm a right?
Yes, that's right.
