Radial vs tangential electric field lines in a solenoid
The discussion centers on the behavior of electric field lines in a solenoid, specifically addressing the assumption that the radial electric field is zero due to the absence of excess charge. This principle is analogous to current flow in a solid conductor, where the electric field aligns with the current direction. The conclusion drawn is that, in ideal conditions, the radial electric field can be considered negligible, allowing for a simplified analysis of the electric field within the solenoid.
  • Understanding of electric field concepts
  • Familiarity with solenoid physics
  • Knowledge of current flow in conductors
  • Basic principles of electrostatics
  • Study the behavior of electric fields in solenoids using Maxwell's equations
  • Explore the concept of electric field lines and their significance in electrostatics
  • Learn about the relationship between electric fields and current in conductors
  • Investigate the effects of charge density on electric field distribution
Students of physics, electrical engineers, and anyone interested in understanding the principles of electric fields in solenoids and conductors.
nosmas
I was reading through an example question calculating the electric field in a solenoid and it made an assumption that the radial electric field must be equal to zero because there is no excess charge in the system. I don't understand when this is true or even why it is true, any suggestions?
Thanks
This is the same kind of argument as current flow in a solid wire. In the solid wire, even though there are charges that will make some charge density, and probably to higher order there is some minimal radial field contribution (such as high voltage power lines), to first order the electric field flows with the current. That is to say that for a perfect conductor E=current flow/resistivity.
  • · Replies 68 ·
9K
