Register to reply
In BJT Ie=Ib+Ic ; Ie-emitter current; Ib-base current; Ic-collector current
by kpraneethin00
Tags: current, ibbase, iccollector, ieemitter, ieib
Share this thread:
kpraneethin00
#1
Apr8-12, 01:36 AM
P: 2
I have three doubts in BJT:
1). in BJT Ie=Ib+Ic ; Ie-emitter current; Ib-base current; Ic-collector current
then i find in many circuits, collector current is given to load, if the emitter current is greater than the collector current, we can connect the emitter terminal to the load, to get more current...
2). why the collector region is large in BJT
3). why the collector region is moderately doped when compared to highly doped emitter
Please help me in this
Phys.Org News Partner Engineering news on Phys.org
A spray-on light show on four wheels: Darkside Scientific
Research project on accident-avoiding vehicle concluded
Smaller artificial magnetic conductors allow for more compact antenna hardware
Jony130
#2
Apr8-12, 05:32 AM
P: 410
Quote Quote by kpraneethin00 View Post
Sometimes we connect the load to emitter, Google emitter follower. But then we lose the voltage gain.
Also kept in mind that the emitter current is greater than the collector current just by a small amount of a base current. So for BJT that have a large current gain β the difference is not significant. Ic/Ie = β/(β+1) for β = 100 -->Ic/Ie = 100/101 = 0.990099009
dlgoff
#3
Apr8-12, 08:55 AM
Sci Advisor
PF Gold
dlgoff's Avatar
P: 2,731
http://hyperphysics.phy-astr.gsu.edu...ds/trans2.html
yungman
#4
Apr8-12, 12:37 PM
P: 3,904
You have to be careful in how the BJT works. Collector current IS CONTROLLED by the emitter current. You design the circuit to setup the emitter current to get the collector current. Collector has very high output impedance where emitter is very low output impedance. Collector is a controlled current source and emitter is a voltage source. Collector current is controlled by the Vbe drop. Yes, Ie=Ib+Ic, but
[tex]I_c=I_s e^{[\frac{V_{BE}}{V_T}]}[/tex]
Emitter being a voltage source, the current is govern by the voltage drop across the resistor connects to the emitter. Collector current reflects the emitter current.
Register to reply
Related Discussions
Transistor Base/Collector Current mystery Electrical Engineering 25
What happens if emitter-base & base-collector junctions are forward biased with 0.7V? Electrical Engineering 10
Collector,emitter and base Electrical Engineering 3
Collector Current through BJT Circuit Engineering, Comp Sci, & Technology Homework 2
Collector current Electrical Engineering 2
