Can you see stars from the surface of a ringed planet?
  • Context: High School
  • Thread starter Thread starter TkyToaster
    Planet Stars Surface
The discussion revolves around the visibility of stars from the surface of a fictional ringed planet, particularly considering the effects of the planet's rings on starlight. Participants explore the implications of ring composition, density, and albedo on star visibility, as well as the potential for light scattering in the planet's atmosphere.
  • Jim Jenkins inquires whether a person on the night side of a ringed planet could see stars, suggesting that visibility might be limited to areas in the planet's shadow.
  • Filip Larsen posits that the visibility of stars would depend on the size of the planet, its distance from its sun, and the presence of moons, which could contribute to ring formation.
  • Larsen suggests that if the rings have a high albedo and are positioned to reflect sunlight effectively, they could obscure starlight, particularly if light is scattered in the atmosphere.
  • Another participant challenges Larsen's conclusions, arguing that while rings may reduce star visibility, bright stars would still be observable, especially when looking away from the rings.
  • This participant notes that as the density and albedo of the rings decrease, more dim stars would become visible.
  • Jim Jenkins expresses satisfaction with the responses, hinting at a narrative element involving the planet being Mars and a hidden Earth-like star.
Participants exhibit disagreement regarding the extent to which rings would obscure starlight, with some arguing for significant visibility of stars and others suggesting that rings could greatly limit visibility depending on their properties.
The discussion includes assumptions about the physical properties of the rings, such as their albedo and density, and how these factors interact with light scattering in the atmosphere, which remain unresolved.
TkyToaster
I am writing a novel set on a ringed planet. The plot calls for the rings to be about a thousand years young, more a torus of gas and dust and speeding moonlets. Would a person standing on the night side of this planet be able to see stars? Or would the rings scatter enough light from the sun to obscure them? I was thinking a person would only be able to see stars in the shadow that the planet would throw across the rings.
Any help would be appreciated.
Jim Jenkins
tkytoaster@gmail.com
Astronomy news on Phys.org
Welcome to PF!
A few comments off the top of my head:
  • I would expect the likelihood of rings to form to depend on the size of the planet, distance to its sun, and likelihood of the planet of capturing a moon. The more massive a planet the bigger the likelihood that a moon ends up in orbits inside the Roche limit [1] of the planet thus providing material for the ring.
  • Any ring material would "quickly" end up in a single orbital plane (rather than a torus) due to collision between ring material. If the planet has any significant bulge of equator I would guess that the orbital plane of the ring is likely to coincide with equator of the planet.
  • If the rings have a relatively high albedo [2] and the rings angle with the incoming sunlight is just right it seems plausible to me that the reflected light from the rings could swamp out the light of all or most of the stars on the night side of the planet, especially if reflected light gets scattered in the atmosphere.
Others here may provide you with better comments.
[1] http://en.wikipedia.org/wiki/Roche_limit
[2] http://en.wikipedia.org/wiki/Albedo
Filip Larsen presents a good discussion; but I disagree with his conclusions.
The highest albedo the rings could have, would probably be about the same as the moon---but the coverage would be far worse (i.e. its a collection of particles, instead of a solid disk). The moon certainly decreased the number of stars you can see near-by it, but you can definitely still see bright stars. Therefore, I would expect that for a very high density, high albedo rings -- you would be able to see only a few very bright stars near the rings itself, but looking away from the rings, you would still be able to see many stars.
As you decrease the density and albedo of the rings, the more/dimmer stars would be visible.
Thanks for replying so quickly and completely. You confirmed what I suspected about viewing stars from the surface of a ringed planet. I wanted to drop a hint that maybe the planet was Mars, where the terra forming had failed, and maybe that blue star mostly hidden by the rings was Earth. It looks like I can safely do that. Thanks a bunch.
Jim Jenkins
  • · Replies 21 ·
