| New Reply |
I want some advice on motorizing my bike. |
Share Thread | Thread Tools |
| Apr10-12, 05:29 AM | #1 |
Hi!
I thought of motorizing my 2 wheeler. 1) Now i want to know how much Voltage (DC motor) is required to turn my wheel. 2) The source of energy? (Maybe Electric). If electric, I know it will be difficult to use batteries to run the motor. Considering car batteries, they are just too heavy. Any suggestions? 3) Throttle. I need some help on that as well, as in synchornizing the wheel movement with the throttle. Thank You. Regards, math_way |
| Apr10-12, 10:23 AM | #2 |
I'm assuming you want to go more than 10 feet?
If so.....4 car batteries hooked in series for 48 volts outta do the trick. I'm guessing 1 HP outta do.....that's about 746 watts for a 48 volt dc motor. P=IV 746=I*48 Current will be 15.54.....so figure 20 amps with magnetic field losses and so forth.....#10 wires outta do the trick to the motor. For throttle....use the same thing they use on the tyco trains....that little slide device that controls the speed of the train. Have a nice day. |
| Apr11-12, 12:07 AM | #3 |
But each car battery weighs roughly 20 lbs... and 4 such batteries will weigh about 80 lbs. That's a little too much weight... any alternative?
| Apr11-12, 01:05 AM | #4 |
I have been looking into this too and I found this on eBay for pretty cheap, I think , lol
It's a kit, they have others if you look http://www.ebay.com/itm/48V1000W26-F...item5ae60f700f |
| Apr11-12, 07:07 AM | #5 |
Electric powered vehicles are difficult to make....and as you can see the power to weight ratio is not very good. There are some electric cars now....but they aren't exactly lighting the world on fire. Not yet anyway. Try a gas motor. The power to weight ratio is amazing. |
| Apr11-12, 08:10 AM | #6 |
Here's possibly a better idea that would be more fun.
Power an DC motor with an AC generator into a full wave rectifier. The AC generator would be powered by your legs. If you could get 1 HP out of your legs....this would translate into less than 1 HP to your motor due to heat and magnetic field losses....but still would be kinda nifty since you are just looking to play around. Maybe you could add a small battery as well that could assist or get charged by your generator as well. Then figure out a way to charge your battery when you were going down hills and so forth.........just like the hybrids. |
| Apr12-12, 02:17 AM | #7 |
| New Reply |
| Tags |
| battery, bike, cycle, motor, throttle |
| Thread Tools | |
Similar Threads for: I want some advice on motorizing my bike.
| moving bike stabilizes but standing bike falls! | General Physics | 10 | ||
| Motor bike engines acting as a gyroscope keeping the bike upright | General Physics | 1 | ||
| How come you have more stability riding a bike than standing still with a bike? | General Physics | 7 | ||
| Shock absorber/Suspension advice (bike project) | General Engineering | 2 | ||
| My bike | General Discussion | 36 | ||
