Can Stars Become Black Holes Without Going Supernova?
  • Context: Undergrad
  • Thread starter Thread starter Routaran
    Blackholes Supernovae
The discussion centers on the formation of black holes, specifically whether stars can become black holes without undergoing a supernova. Participants explore the conditions under which massive stars collapse, the processes involved in supernovae, and the implications for gravitational fields around black holes.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • One participant questions if a massive star, upon exhausting its fuel, must always go supernova before collapsing into a black hole, or if certain mass thresholds allow for direct collapse.
  • Another participant explains that core-collapse supernovae typically occur in stars between 8 and 30 solar masses, while black holes are formed from stars above 30 solar masses, potentially through direct collapse or fallback mechanisms.
  • It is noted that during the collapse of a massive star, the core can become so hot that it may explode, but the energy may not be sufficient for the material to escape, leading to a black hole formation instead.
  • One participant highlights that iron fusion in the core of a massive star halts energy production, causing the outer layers to collapse without an explosion, resulting in either a neutron star or a black hole.
  • A follow-up question addresses the gravitational effects on a planet orbiting a star that collapses into a black hole, questioning whether the orbit would remain stable given the mass is unchanged but compressed.
  • Another participant responds that if the black hole has the same mass as the original star, the orbit would remain stable, although mass loss during the formation process could affect this stability.
  • Concerns are raised about potential 'kicks' a black hole might receive during formation, which could alter its velocity and potentially impact nearby orbits.
  • Participants discuss the implications of gravitational forces, referencing Newton's law and the concept of treating symmetrical mass distributions as point masses for gravitational calculations.
Participants express various viewpoints on the processes leading to black hole formation and the effects on surrounding gravitational fields. There is no consensus on the specifics of the collapse process or the implications for orbits around black holes.
Limitations include the complexity of stellar evolution processes, the dependence on mass thresholds for different outcomes, and the unresolved nature of certain mechanisms involved in black hole formation.
Routaran
I have a question about the formation of black holes.
Correct me if I am wrong but as I understand it, if you have a massive enough star that when its used up all its fuel and collapses, it will overcome the exclusion principle and crush itself into a black hole.
My question is, during this collapse, doesn't the core of the star get hot enough for it to become a supernova?
Basically, while the core is collapsing, on its way to becoming a black hole, shouldn't the star also go supernova? and if it does, how do we end up with a black hole after the star went bang?
Or is there another size bracket there so that if a star is within a certain range for mass, it will go supernova but if its bigger then it just collapses into a black hole faster than it has a chance to become a supernova?
Thanks
Space news on Phys.org
Great question.
Short answer, take a look at this schematic:
http://startswithabang.com/wp-content/uploads/2008/04/star2evo.jpg
Keep in mind, it is very schematic.
The two main categories of supernovae are core-collapse, and thermonuclear. In general core collapse supernovae occur from stars more massive than about 8 solar masses, and less than about 30. These generally look like 'Type II' supernovae, and produce neutron-star remnants.
Thermonuclear supernovae are the explosions of white-dwarfs (which form from stars between about 2 and 10 solar masses), which (we think) look like 'Type I' supernovae, and leave no remnant (i.e. just a nebula).
Black-holes are produced by more massive stars, i.e. those above about 30 solar masses via either "direct collapse" or "fall-back". For stars right around 30 solar masses, exactly what you guess happens---as they collapse, they get so hot that they explode... but the explosion doesn't have enough energy for the material to escape, and it ends up falling back to the center and forming a black-hole. Direct-collapse is believed to happen in very massive stars which huge iron cores. The gravity of these stars is so strong that their material is completely sucked in, with little to no emission.
The details of these processes aren't entirely clear---especially when it comes to the electromagnetic signatures expected from their collapse. During the formation of a black-hole, so much material is consumed that there isn't really enough stuff released to make a bright supernovae. In the end, no matter how hot the material gets---there's just too much gravity.
For something of a summary of these stellar-fates:
http://hera.ph1.uni-koeln.de/~heintzma/SNR/bilder/SN_NS.gif
Nice one, zhermes.
One of the unique properties of iron is that it takes more energy to fuse iron into another element than is released by the fusion process. So when the core of a massive star fuses to iron the core stops radiating energy. The outer layers of the star collapse at something like a quarter of the speed of light and crush the iron core. The iron does not explode, for the above reason, but becomes a neutron star or a black hole.
Also, a white dwarf star does not simply become a Type Ia SN unless it accretes mass from a companion star or perhaps collides with another white dwarf.
http://www.optcorp.com/edu/articleDetailEDU.aspx?aid=1665
thanks for the reply zhermes, that makes much more sense to me now.
thanks arch for the link, i had a very very basic understanding of type Ia supernova, just that white dwarfs steal matter from a companion star and go pop, it was a very good read and i enjoyed learning how it works.
another follow up question with regards to the gravitational field around the black hole, specifically how it changes.
lets say there's a planet in a stable orbit some distance away from a given star that collapses and forms a black hole. let's assume for a minute that the planet survives and is otherwise not blown to bits.
now whenever dealing with black holes, people generally picture incredible amounts of gravity. but the total mass of the star/blackhole hasnt really changed. its just been compressed into a very tiny volume.
would a planet that used to have a stable orbit around the star, still have a stable orbit around the black hole?
from very close to the star (or perhaps inside the star) i can imagine feeling significant changes in the gravitational field. what used to be a fairly spread out mass pulling you in different directions now is pulling you all in one direction (cuz its small) but from a distance, would you notice something as happened strictly by feeling the gravitational pull of the star?
Routaran said:
...people generally picture incredible amounts of gravity. but the total mass of the star/blackhole hasnt really changed. its just been compressed into a very tiny volume. would a planet that used to have a stable orbit around the star, still have a stable orbit around the black hole?
If you replaced the star with the same mass black-hole, then yes - the planet's orbit would not only still be stable---it would be (virtually) exactly the same. The complicating factor is the formation process of the black-hole, which, in particular, would involve some amount of mass loss. The amount of mass loss determines how much it would perturb the orbit. For the planet to become unbound, the star would have to lose at least half of its mass (I think that's right...). One final complicating factor is that black-holes might get 'kicks' when they form --- the explosion during the collapse of the progenitor star might not be perfectly symmetric, and could act like a rocket - giving the black-hole some velocity. We don't know if/how-much this happens, but most likely it wouldn't have much of an effect (I don't think).
Excellent question. The story goes that Newton invented* calculus to solve (essentially) this problem. He wanted to know how you can add together the effects of every individual piece of an astronomical body to get the resulting gravitational force (which he new was the 'inverse square law' --- what we call Newton's law). What he found was that it doesn't really matter what the matter distribution is like, as long as its roughly symmetrical --- you can pretend its a 'point-mass' and the gravity will be the same.
Thus, as I said above, if you replaced the star with a BH (of the same mass) the effects of gravity would be the same.
* - I'm not sure how accurate this 'story' is; but one important thing to note is that Liebniz seems to have also independently invented calculus. Generally mathematicians will say Liebniz, and physicists Newton.
Thanks for the replies. I think I understand it a little bit better now.
Cheers.
  • · Replies 57 ·
  • · Replies 17 ·
  • · Replies 53 ·
  • · Replies 0 ·
