Uncertainty Propagation for the Slope of a Line of Best Fit
The discussion revolves around the calculation of uncertainty in the slope of a line of best fit derived from experimental data points with associated error bars. Participants explore methods for propagating uncertainties in a linear regression context, addressing both theoretical and practical aspects of uncertainty analysis.
  • One participant seeks guidance on calculating the uncertainty in the slope of a line of best fit using data points with error bars.
  • Another participant suggests referring to regression analysis formulas, noting that uniform errors may complicate the situation.
  • A participant expresses confusion about applying the standard error formulas, indicating a need for clarification through an example.
  • There is a proposal to consider breaking down data points into combinations of maximum and minimum values to incorporate error bars into the analysis.
  • One participant mentions the need to adjust the analysis for varying error bars and suggests that optimization conditions might need to include weighting factors based on data point precision.
  • Another participant highlights that standard regression formulas assume uniform error distribution and suggests using maximum likelihood estimation (MLE) for cases with heteroscedasticity.
  • A participant proposes using Gaussian distributions for error bars and discusses the potential use of Monte Carlo methods to assess the distribution of the slope.
  • Bayesian analysis is mentioned as a possible approach for properly incorporating uncertainties in the slope and intercept.
Participants express differing views on the appropriate methods for calculating uncertainty, with no consensus reached on a single approach. Some advocate for traditional regression techniques while others suggest more complex statistical methods to account for varying error bars.
Limitations include the assumption of uniform error distributions in standard regression analysis and the potential complexity introduced by varying error bars. The discussion also touches on the need for more advanced statistical methods, which may not be universally agreed upon.
Kyle91
Hi guys,
So I'm writing up a physics lab and I have a bunch of data points. All of these data points have both x and y error bars. The relationship between x and y is linear and so I've made a line of best fit using Python passing through the data.
Now the slope of that line of best fit has physical significance and I need to know its value. Of course I know the gradient of this line but what I don't have is the uncertainty in this gradient - which I need.
How can I go about calculating it?
Thanks!
This section should help if you can follow it:
http://en.wikipedia.org/wiki/Regression_analysis#Linear_regression
At the bottom it gives you a pair of formulas for the standard error of the parameter estimates:
This works if the errors in the data are uniform. For your work it might be more complicated than that.
Hey thanks for the link! I had a read through but I'm still not fully understanding it. Could you please run me through an example? Let's say I've three data points -
(0 +-0.1, 8 +-0.5), (1 +-0.2, 10 +-0.4), (2+-0.3, 12+-0.6)
With my line of best fit being y = 2x + 8.
Edit: Oh so I only need the second equation you've listed because I only care about the gradient right? Even so I'm still not 100% on how to use it.
So I thought I just figured it out. I used the above data points but no where in that formula did it ask for the error in my points. I think that formula is solely used to find the error assuming the data is 'almost linear'. For example if my data points were (0, 8.1), (1, 10.1), (2, 12). There isn't a linear relationship there but this formula would tell you the 'error' in the slope.
This isn't the same as my scenario as I want to factor in my error bars into my formula. Maybe I should break all of my points up into (x-max, y-max), (x-min, y-max), (x-min, y-min), (x-max, y-min) and then sub them into that formula?
You may need to change your variables so that a straight line relationship 'should' apply. Plotting X against y squared or log y or something ( the theory of your particular experiment would tell you what to do) and then I think you could do the analysis on the resulting set of data OK.
This is the same trick as you would use if you wanted to do it with a ruler on graph paper.
I've already got the relationship such that a straight line will apply.
I've made a quick mock up of my actual data - see here http://imgur.com/fbwIb.
So what I need to do is find the error in that light blue line. Of course the obvious and inaccurate way to do it would just be to alter the formula by hand in my code until it leaves the error bars, but I don't want to do this as I feel I should have a numerical method.
Furthermore if I were to find the uncertainty via this method I'd be overlooking the proper way to do uncertainty analysis. For example if I have a line segment that is 1m +-0.2m and another line segment that is 2m +-0.1m and I want to add them together it is not simply 3m +-0.3m. You can't just add the errors, you have to follow this formula http://imgur.com/2EidJ. So the error would be sqrt(0.2^2+0.1^2) or +-0.22m. I worry I'd be overlooking this if I just vary the gradient by hand until it no longer fits the error bars.
SO you are suggesting here the data has varying error bars, I don't know the answer but I imagine it's somewhere in that long article. My guess is the optimisation condition (minimise sum of squared residuals) must be adjusted to include weighting factors depending on the precision of each data point.
Furthermore I'm not sure if this caters for horizontal error bars. If there's an error in your independent variable then you might need to also change the optimisation condition for this, eg., rather than use residuals in the vertical direction, calculate the minimum distance from the point to the line and square that, then sum it, or calculate the distance from the point to the line along some bearing which depends on the ratio of the horizontal/vertical error bars.
The work has probably been done but I've never studied statistics in this depth. I'd be very keen to know the answer as well.
The standard formulae for regression analysis assume the error distribution is the same for all datapoints (i.e. as random variables the error terms are i.i.d.)
If you have error bars that vary with the data values (heteroscedasticity, since you ask) then the normal straight line fit formula is not right. You need to bias in favour of matching the more reliable datapoints.
The general method is MLE - maximum likelihood estimation.
First, you need to convert the error bars to actual distributions. You could simply take them at face value and say the distribution is uniform over the range of the bar, but that is not likely to give you a good result. Instead, I would suggest taking each datapoint to have a Gaussian error, with the error bar indicating the standard deviation in each case (1 sigma, 2 sigma, whatever you choose).
Then you need to pick the slope which maximises the overall "likelihood":
Datapoints: (Xi, Yi)
Model: Y = mX+a
Error: Ei = Yi - (mXi+a)
Std devs: Di
Find m, a to minimise: Ʃ(Ei/Di)^2
Turning to your original question, you want to find the distribution of m.
This is a bit tricky because there could also be an error in a.
One approach is Monte Carlo: generate random datasets fitting m, a, Di, apply the above procedure, and see what distributions you get for the computed m and a values.
To do it properly might require Bayesian analysis: pick a priori distributions for m and a, then adjust them based on the data.
  • · Replies 28 ·
