Differential equation for motion of a pendulum
The discussion focuses on modeling pendulum motion using a differential equation in Matlab, specifically addressing the equation of motion: \(\ddot{\phi}(t) = -k_2\dot{\phi}(t) - k_3\sin(\phi(t))\). The user seeks to modify this equation to achieve a sinusoidal solution, while also considering non-linear components such as friction. The common approach suggested involves linearizing the equation by approximating \(\sin(\phi(t))\) with \(\phi(t)\) under the assumption of small angle swings.
  • Understanding of differential equations, particularly second-order equations.
  • Familiarity with Matlab for modeling and simulation.
  • Knowledge of non-linear dynamics and friction effects in mechanical systems.
  • Basic grasp of linearization techniques in physics.
  • Explore Matlab's ODE solvers for simulating differential equations.
  • Research the method of linearization in the context of pendulum motion.
  • Study the effects of damping and friction on oscillatory systems.
  • Learn about sinusoidal functions and their applications in modeling periodic motion.
Students and researchers in physics and engineering, particularly those interested in mechanical systems, pendulum dynamics, and numerical modeling in Matlab.
fiso
Hello,
I'm trying to create a model of pendulum motion in Matlab to fit the curve we measured in class, and it has some non-linear components (friction). It looks like the best fit is a sinusoid with an envelope given by a parabola (see attached file).
The equations of motion are given by:
[itex]\ddot{\phi}(t) = -k_2\dot{\phi}(t)-k_3\sin(\phi(t))[/itex]
How this equation can be changed so that the solution of it is a searched sinusoid?
Thank you.
// edit: please move this to Differential Equations
The usual approach is to linearize, assuming the angle of the swing is small, so replace sin(φ(t)) by φ(t).
  • · Replies 32 ·
  • · Replies 17 ·
